This is the start of the official gar1731 build.
NOTE TO FOLKS SOURCING THEIR OWN PARTS..1/27/2020The BC560C is no longer being manufactured. If you can
Not source these, with lots of listening time with lots of different
PNP transistors, we have come up with suitable replacements.
gar2520 Q6 and Q9
gar1731 Q3 and Q4
garAM10 Q1, Q5, Q6, and Q7
(gar918 and the gar OA10 will have other recommended replacements)
First choice BC32740TA Mouser Part# 512-BC32740TA
Second choice BC557BF Mouser Part# 512-BC557BTF
Note that both of these transistors have the same pinout as the BC560C
So you should be able to just drop them in place using the silk on the pcb.
If you want to experiment with other PNPs, Make shure the Vceo max
Is at least 45v. hfe is not all that important for these PNPs but above 250
Will work fine. Just be aware of pinout.
All of my kits until future notice, BC560Cs will be included in the kits. NOTE: DUE TO SUPPLY CHAIN, SOME KITS MAY HAVE THE DIODES LOOSE
PACKED WITH THE RESISTORS INSTEAD OF ON TAPEMany questions will probably be answered in the gar1731's big brother thread...
http://www.groupdiy.com/index.php?topic=33970.0 (gar2520 build thread)
As this thread is a bit more mature at this point.
The BOMs are similar and construction techniques are the same.
I think the gar1731 assembly manual is a bit better than the gar2520 assembly manual
So the questions should be few but fire away if you got them.
1) The little bag with the Millmax pins also contains the matched Q1 and Q2. (BC550c)
and are labeled as such.
2) The little bag with 2 transistors without the pins contain Q5 & Q6. (BC550c)
3) The tape strip with 2 transistors are Q3 & Q4 (the BC560c)
4) The little bag of 5 caps..
The tan ones are CD1, CD2.
The blue ones.. see page 2 of the assembly manual for value and page 3 for location.
5) Please meter the resistors to determine value.
6) After assembly PLEASE double check for unwanted solder bridges
on the Bottom of the PCB. and make SHURE THAT on the top of the
PCB that no component lead wires are touching each other.
7) When inserting your new DOA into the millmax sockets of
a module, Please insert straight down and not at an angle.
DO NOT push down on the component parts but use the edges
of the DOAs PCB. Remove DOAs the same way. Pull straight up
from the edges of the PCB and not at an angle.
8 ) Never insert a DOA or a module with the power on.
9) HAVE FUN !!
GARY
NOTE: Manual update ... Step 24 should read Q6
AND Q5
Note.. Murata has changed the marking on the Blue 10pf cap from 10D to 10J
These two parts are exaxctly the same. (D = +/- .5pf and J = 5%)
You may see either one of these in my kits.
Note: Dec. 7 2013
MURATA IS DISCONTUNING THE RPC SERIES OF CAPS USED IN THE gar2520 and gar1731!!
The RPE series is being replaced with the RCE series. I will be phasing these in as my RPE
Stock diminishes. I will be using either 50v or 100v based on availability. For you guys buying
Raw PCBs and sourcing your on parts here are some part numbers:10p 50v.. RCE5C1H100J0A2H03B
10p 100v. . RCE5C2A100J0A2H03B
39p 50v.. RCE5C1H390J0A2H03B
39p 100v.. RCE5C2A390J0A2H03B
47p 50v.. RCE5C1H470J0A2H03B
47p 100v.. RCE5C2A470J0A2H03B
680p 50v.. RCE5C1H681J0A2H03B
680p 100v.. RCE5C2A681J0A2H03B
1000p 50v.. RCE5C1H102J0A2H03B
1000p 50v.. RCE5C2A102J0A2H03B
In a pinch the AVX SR15 series...
50-100v 5% with a lead spacing of 2.5mm (.1”)
Should work fine as I have tested these
