Hello folks,
I recently saw a SSL9K Mic pre, 4 of them in fact, in a 1U enclosure.
I thought to myself, how can I squeeze the mic-pre-front-end controller into a vertical 1U strip?
(http://www.expataudio.com/expatshop/index.php?act=viewProd&productId=6)
Trying to get 3 switches, plus a microcontroller, the power supply (3.3V from the system 15V) onto a small card that's 1.5inches tall, and as narrow as possible (to get as many in a case as possible) is a tall order, and one I think I can only solve with some SMD components.
Now, I've seen the attitude towards SMD change here over the last few months, where people are starting to consider it an option.
So, the question is -- would you prefer expat audio do the hard work in mounting the SMD parts (leaving the easier thru hole stuff for you), or would you prefer to solder them yourself?
