thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
A client has asked me to add a sweepable HP shelving filter to an item of his. He claims that his previous tech made such a device with a passive / inductor circuit...(said tech is not available for comments...). I'm not aware of how such a thing could be done without an active circuit, i.e. a state-variable filter. Not only that, but even a passive circuit with greatly limited sweep range is a) going to need to be driven from a relatively low-Z source, and b) need some make-up gain on its output. By the time you've factored everything together, is there any point to the passive solution?
How many ways are there to make a passive HP filter? Can a passive be swept at all? Can anyone post links to examples?
Thanks in advance.
Justin
Thanks in advance.
Justin
