As I understand, a grid resistor and the capsule forms a high pass filter, transformer coupling cap an other one (and a cathode resistor bypass cap a shelving filter if used).
In classic circuits the transformer coupling cap is the one that does the high pass job, right? But if you want to high pass why not doing it before the signal hits the tube? I remember reading about this in some thread here but can't find it anymore.
Second, I'm planning to put a switch in my mic for different cathode bypass cap values. Three different caps, one for flat response, one for low shelving (compensation for proximity effect) and one for high boost (very low value cap). Any drawbacks expected for this kind of switch?
