M marktokach Well-known member Joined Feb 5, 2008 Messages 169 Location New Braunfels, TX May 13, 2010 #1 I get that most of the parts go on tracks side. With polarized caps does the positive leg still go in the same hole just from the tracks side?
Skylar Well-known member Joined Sep 16, 2005 Messages 1,021 Location Irvine, CA May 13, 2010 #2 Put the positive leg through the hole labelled with a + regardless of which side you mount the capacitor. When in doubt, look at the schematic and see where the positive leg is connected, then follow the traces on the PCB to confirm your placement.
M marktokach Well-known member Joined Feb 5, 2008 Messages 169 Location New Braunfels, TX May 13, 2010 #3 Thank you
