niccolo gallio
Member
Hi there, I' looking for some informations about R115 pot, used to determine the AC threshold of the compressor.
I'm attaching a snip of he schematics for reference.
My questions are:
1) the schem is not very clear about the actual value of the pot, is it 100K or 180K?
2) I've seen around that the center tap of a pot is often rated as a percentage, and most of the center tapped pots I've came across (mainly used for volume+loudness control) are 60% 40% - Do you know what percentage is the center tap rated in R115? Is this value vital to the operation of the device?
3) These pots - 100k dual linear with center tap - are quite hard to find, maybe only on custom order thus costing a lot, what is the drawback here if using a pot with the aforementioned specs but lacking a center tap?
4) Can a center tap be "faked"? i.e. can I fake the operation of a center tapped pot using extra components as voltage dividers?
thank you very much for taking the time to read this post
niccolo
My questions are:
niccolo
