Thanks PRR , in the pdf is just the blockdiagram , no schemo. So will ask them what they have , is a company in my own country and i didn't know that it exist.
For HG yes it is easy to change the digitech , the only problem you have is that there is no space inside anymore so you have to do it outside.
The new extra trafo for the +/- 18V is put on the backside , nice small type of ERA 30W flattype , will fit , make 230V to the switch and get the old wiring from the "old" trafo of the rectifier and put the new trafo instaed on it. You still need the "old" trafo for the rest to power it. (the tube)
The LM7818/lm7918 must be put on the backside aswell with heatsinks on them because they get a little bit hot , therefor it need a little bit more air , so make a few more holes in it and watch it in temp.
