Pictures!
(couldn't find my Digital slr camera so it's cellphone-cam...)
and some more inside pictures
http://i391.photobucket.com/albums/oo352/arnolievens/calrec/IMG_0518.jpg
http://i391.photobucket.com/albums/oo352/arnolievens/calrec/IMG_0519.jpg
http://i391.photobucket.com/albums/oo352/arnolievens/calrec/IMG_0522.jpg
http://i391.photobucket.com/albums/oo352/arnolievens/calrec/IMG_0514.jpg
Fpd file emailed.
Panel was made by schaeffer-ag and has no infill. Might be more readable with white text.
You should pay attention with the pots. The dual 100KC pots are hard to find so it will depend on them which size you use (10mm, 8mm or 1/4" holes and spacing from the pcb)
I used omegs from AML for freq and vishay spectrol cp pots for boost/cut but their solder pins turned out to be too short...
You might wanna wait with soldering the spun switches in completely. I started out with one pin first, and repositioned after the pcb was inserted.
Actually, I did that after I replaced all toneluck switches for alps because they had longer pins and the pots didn't allow me to mount the switches flat on the pcb.
If I had to do it again, I would consider placing the Q switches higher on the front panel, which was designed for smaller pots than the omegs. But I'm really happy with the result I have now.
