mnats
Re: MixBuzz500 build/support tHread
« Reply #240 on: May 08, 2011, 07:54:57 AM »
Thanks Igor - Works great!
I've posted some notes here: http://mnats.net/mixbuzz_500_build.html
« Reply #241 on: May 09, 2011, 08:00:26 AM »
Congrats mnats!! Your notes are really great too. I'm going to put a link in my "How to build a Mixbuzz 500 step by step" if you don't mind :http://www.groupdiy.com/index.php?topic=40493.msg553174#msg553174
I need some help with the SYM trimmers. I have no distortion meter so I used the method Igor suggested 0 volts on the output pins of IC 11 (opa2604). The thing is that it is constant drifting. In the beginning much more and after 30 minutes some millivolts. The other thing is that the trimmers are at there end position and I'm using 4x 2181A's on the VCA boards and also 2181A in the sidechain. (It was cheaper to order 10 x 2181 of the same model)
Is there some freeware distortion meter?
Do I leave out R33 and SC_SYM and forget the DC on pin 1  of IC11?
Is there another way?
noulou
« Reply #242 on: May 10, 2011, 04:35:48 AM »
brilliant kit as usual, thanks Igor!
wowi
« Reply #243 on: May 14, 2011, 11:40:55 AM »
One more 500 Mixbus ready here, but ... a little bug has survived:
The left channel has 3db more output than the right. This occurs, even if the threshold is turned up, so that there is no compression.
When i go on bypass, everything is ok. Both channels compress and sound as they should.
Any idea where to look ?
Wolfgang
« Reply #244 on: July 18, 2011, 08:18:50 PM »
Which VCA's used?
Wrong resistor in audio path, maybe... Wrong resistor at VCA PCB...
Or, 5534 at VCA PCB has too much offset....almost impossible.
Other-vice, IF the CV at one side was not correct... But the control voltages are tied together.
As usual, CHECK EVERY PART, and you'll find the mistake.
@Mnats: awesome!!!! I just reading
http://mnats.net/mixbuzz_500_build.html.
Man, I have to learn from you how to give REAL build support!!!!
I wish to have bit more time, as well))
« Last Edit: July 18, 2011, 10:23:26 PM by Igor »
http://www.ij-audio.com
(new site hopefully will be up in July)
Marcocet
« Reply #245 on: July 29, 2011, 06:16:36 PM »
Okay, here's where I'm at
I finished putting the unit together. It powers up, and I can hear the relays clicking as I go in and out of bypass. The meter is showing gain reduction as I turn the threshold knob. However the audio doesn't seem to be effected at all, and the make up gain doesn't change the output either.
Any thoughts? I can't seem to track it down... Thanks
culteousness1
« Reply #246 on: July 29, 2011, 06:40:43 PM »
You may check RightMark Audio Analyzer:
http://audio.rightmark.org/index_new.shtml
It's abled to measure the Total Harmonic Distortion and there is a free version.
Carsten
"What's all this analog stuff anyhow?" - Bob Pease
"My favorite programming language is ... solder." - Bob Pease
« Reply #247 on: July 30, 2011, 01:40:52 PM »
Strange... Did you connected the power supply of small (control) pcb?
Marcocet
« Reply #248 on: August 03, 2011, 10:37:36 AM »
Yes. The bypass LED is functioning perfectly, and the meter appears to be showing gain reduction although the output is not being effected. I can hear the relays clicking when I flick the bypass so I assume that's not the issue. Any other thoughts?
I'll take some pictures when I get a chance to put my hands on it again. Thanks
« Reply #249 on: August 03, 2011, 04:16:28 PM »
Great. Let's check:
When turning MAKEUP and THRESHOLD pots, at the pin 7 and 8 of IC7b the voltage should change within range of couple of volts,
(without getting deep into precision mathematic) :)
If yes, check resistors R60=100r, R75=49r next.
Than, go to audio board and check if there's voltage change when rotating the trimpots at CTL connector, pins 1 and 3
(or, check at R100, R45). Check R100=909R. Maybe, bad contact at pin 1 of CTL connector.
If this does not helps, check on VCA adaptor PCB: R101=732R, R102=100r, check if IC9 (NE5534) installed correct as well.
Marcocet
« Reply #250 on: August 08, 2011, 11:58:24 PM »
Found it. I'd done the calculations for R100 right (using a 202C) but somehow put the wrong value in! The makeup not working was just a bad contact.
It's totally awesome. Thanks for all the help and for your hard work Igor.
« Reply #251 on: August 09, 2011, 02:41:34 AM »
Cool, enjoy!
timmygrimm
« Reply #252 on: September 25, 2011, 08:27:49 PM »
I'm trying to put together Mouser part numbers for everything.
https://www.mouser.com:443/ProjectManager/ProjectDetail.aspx?AccessID=d986302f5e
I think I got everything with the following exceptions:
- 6.8uf audio grade caps (C38) arent available through Mouser. Don't know if I can sub in a value or just find a different source.
- Mouser seems to have no 5mm LEDs...
- I'm not sure what to order for the PCB INTERCONNECT SOCKET/RAW CONNECTORS.
- Got the 10 pin male headers, but couldn't find any female sockets with horizontal wire mount like I see in people's photos. I put this http://www.mouser.com/Search/ProductDetail.aspx?R=M80-8881005virtualkey57420000virtualkey855-M80-8881005 in the project, but not sure if it will fit / work.
- I put these ferrite beads on the order but not sure if they will fit. http://www.mouser.com/Search/ProductDetail.aspx?R=4212-2virtualkey51820000virtualkey807-4212-2
- I ordered 2181A(s) as per BOM, but others say 2180A is best choice? Confused...
- Not sure which 10 connector wire to order (gauge, etc). Options here: http://www.mouser.com/Wire-Cable/Flat-Cable/_/N-5ggm?P=1z0vl9dZ1z0vt0b
If people wouldn't mind double checking my work... I spent quite a bit of time trying to get things right (cross-referencing Farnell parts), but I have have had some completely unusable parts show up on my doorstep before, so any help would be greatly appreciated and hopefully other US people can benefit from this. Tried to put Igors ref #s on things, but alas some are missing.
Tim
« Last Edit: September 26, 2011, 02:03:04 AM by timmygrimm »
« Reply #253 on: September 25, 2011, 11:21:53 PM »
Hi, I am not very familiar with Mouser, BTW, scroll this thread, there was an alternative BOM with all p/nr's from Digikey or Mouser IIRC.
Will try to help...
Tantalum, 16-25V
No way :)
Check Farnell 7991967 and  1022262 ; Mouser should have similar products.
Others, aye! :)
2181A will work absolutely fine. 2180 is pre-trimmed, the only difference
HEADER, STRAIGHT, 10WAY
http://il.farnell.com/avx-interconnect/008380010000010/header-straight-10way/dp/636332?Ntt=636332
Socket, IDC, 10 way
http://il.farnell.com/avx-interconnect/008290010000011/socket-idc-10way/dp/636034?Ntt=636034
Hope this helps.
timmygrimm
« Reply #254 on: September 26, 2011, 02:05:37 AM »
Thanks Igor!
I scrolled through the whole thread again and didn't see an alternative BOM, but I looked through your suggestions and think I have everything covered.
I'm wondering if cut dip-16 sockets will work for the 2181s since the spacing is pretty tight, but it seems like the only option.
Anyway, I'll order this and update the thread if there are issues.
Tim
« Reply #255 on: October 01, 2011, 03:10:37 PM »
Mouser: haven't passed one-by-one, but looks allrighty. The ferrite beads are bigger than I used, but will fit.
More inductance won't be worse here.
This is exactly what I did too.
BTW. Helpful info from people who built MB500:
http://www.groupdiy.com/index.php?topic=40493.0
bkbirge
« Reply #256 on: October 12, 2011, 12:02:42 AM »
Man, that's a great timesaver, thanks for sharing. Just finished my 51x rack and gearing up to start this project finally after having the PCB's for over a year.
Thanks Igor!
Tim
bkbirge
« Reply #257 on: October 16, 2011, 11:53:28 PM »
Build in progress pic. Almost done, missing some parts from the BOM and some mismatches etc.
bkbirge
« Reply #258 on: October 17, 2011, 11:53:25 AM »
Question about the bypass caps on the vca boards, the BOM says 220uf but that is different compared with the other boards' BOM, seems it should be 220pf ? Which is correct, thanks!
Also, any plans to finish up the crush & blend w/MS expansion?
« Last Edit: October 17, 2011, 11:58:33 AM by bkbirge »
bkbirge
« Reply #259 on: October 25, 2011, 06:10:36 PM »
All built! Now I just need to calibrate. I've put 2180A's in the build, the pre-trimmed vca's, how does this change the calibration procedure, if at all? I do have all the trimmers installed, figured I'd do that in case I swapped out for 2181's at some point.
Last post January 08, 2020, 01:13:55 PM
by Spencerleehorton
Last post May 27, 2020, 06:20:38 AM
by eternal slang
Last post April 24, 2020, 09:32:44 PM
by Blondino
Last post April 24, 2019, 06:18:12 PM
by Mrosso
