Please help with a late 30's preamp
« on: June 13, 2010, 01:02:49 AM »
Amp: Northern Electric (Canadian Hammond) organ preamp circa 1937, no internal B+ supply. Newly rebuilt, original power and output transformers. Please refer to schematic: http://farm5.static.flickr.com/4053/4694201969_4eb60a021b_b.jpg
Symptoms: somewhat quiet output and a prominent 60 cycle hum.
Here's what i've got so far after poking around with the scope and multimeter. Any ideas are appreciated!
- Power transformer measures 6.3v with centre tap to ground.
- Measured 6 to 8 volts 60hz ripple between chassis ground and either side of the output transformer secondary.
- No ripple on the primary.
- Only 0.1V ripple between two ends of secondary. Same 0.1V ripple is present on the B+ feeding this amp from the Leslie cabinet (320VDC).
- Checked for transformer leaks to ground, got infinity resistance between all transformer wires and ground. Tried disconnecting the centre tap ground, same results - I don't know the purpose of this ground.
- Checked output transformer with 12V AC adapter (actually reading 16V). Measured 1.25V on secondary, giving 12.8:1 ratio. Spec is 4000:200 which would be 20:1. Bad transformer?
Thank you,
Adam
Re: Please help with a late 30's preamp
« Reply #1 on: June 13, 2010, 02:01:40 AM »
Do all the plate and cathode voltages look reasonable?  Sounds like a wire may not have gotten connected during the rebuild.
 Have you replaced all electrolytics?
The step down ratio is ~ 4.5:1  so a 12VAC signal on the pri should give you ~3.5V on the sec.
Check all the existing circuit grounding and make sure it's tied correctly within the preamp and to PS ground.
The CT ground is for providing a balanced reference to ground in the filament circuit - it's there to minimize hum.  Double check that that connection is solid.
Swap tubes if you have spares.
Have you tried interfacing it to 2 different destinations?  Same results?  If one hums and the other doesn't check to see how the input ground is tied in on the Leslie power amp.
One last thing - Are the leads on the OT pri connected as they were originally(red to plate, Brn to B+)?.  I've had a strange case of AC voltage where it shouldn't be in a single ended circuit that was solved by reversing the pri leads.
Last post December 24, 2009, 04:58:37 PM
by strangeandbouncy
Last post July 03, 2010, 07:24:06 PM
by analag
Last post September 19, 2010, 09:48:49 AM
by EmRR
Never too late
Started by DaveP « 1 2 » Brewery
Last post August 19, 2019, 01:46:46 PM
by Winston O'Boogie
