I'm troubleshooting an ampeg SVT350. The owner ripped the eq faders off while putting it in the trunk.
He doesn't mind very much for the faders as he never uses them.
In the beginning it was making crackling noises which turned out to be a bad ground connection.
I managed to fix that.
Now I'm searching for another problem.
The fan never works, the relay that switches the speakers in and out works most of the time.
The schematic of that part is here:
The full schematic can be found here.
http://www.filestube.com/92534ccf524b9af303e9,g/Ampeg-B2.html
I made some measurements,
the fan works when connected to a 9V battery. Out of circuit it measures 250k. It's a 24Vdc model.
When the fan is out of the circuit there's about 55V on it's terminal, when connected this drops to about 2V.
