Variable-directivity condenser microphones operate with dual capsules. These are constituted of a two cardioid capsules back-to-back, which are connected in parallels AC-wise, so their output voltages are summed. By varying the bias voltage of one of the capsules respective to the other, the summation gives differnt results.
If the bias of the rear capsule is null, its output voltage is null, and then the combined voltage is that of the front capsule, i.e. cardioid.
When both capsules receive the same bias voltage, their voltages add linearly; the output is the same when the sound comes from any direction (in fact, depending on the physical characteristics of the capsule, there is some narrowing of directivity at HF, but the front and rear sensitivity are equal).
If the rear capsule bias is of opposite polarity, the front and rear sensitivity is equal but out-of-phase, and lateral sensitivity is null, giving the typical figure-8 pattern.
Several mics offer intermediate positions like very wide cardio, wide cardio, not-so-wide cardio, hypocardio, hypercardio, supercardio, megacardio, figure-of-peanut...
For practical reasons (unavailability of negative voltage), very often the backplate is at a positive voltage and the diaphragm of the front capsule at zero; consequently, the voltage on the rear diaphragm is varied between zero and twice the nominal bias. In cardio mode, the rear diaphragm must be sitting at nominal bias, in omni it must be zero, and in figure-8 it must be elevated at 2x nominal.
In a U67, the backplate sits at 60V, the front diaphragm is at zero, and the rear diaphragm is at the same votage (in fact directly in parallels) in omni mode, completely disconnected in cardio, or bias at 120V in figure-8.
