EAGLE board layout question
benidubber
Valencia, Spain
hi!
in EAGLE layout editor is it possible to quickly repeat the same routing for 2 identical parts of the same circuit?
For example:
you want to design on a single board 2 identical channels and the PSU for both,
how can you copy the routing made for the first channel using the components of the second?
manually of course..
.. a quicker solution?
thanks
sandro
Check out a ULP called copyplacing.  It should be on eagles website.  I have tried a ULP that copies the traces as well, but haven't had much luck.  Let me know if you get it working though.
benidubber said:
hi!
For example:
thanks
sandro
How about this?
http://www.eaglecentral.ca/forums/index.php?t=msg&th=38001&start=0&S=b6bc7f0bcb0ffc4cfc3cd8074eb02aa4
Bruno2000
Thanks Bruno, that's the way!!
I'll try right now.
I can't make work the duplicate v45 ulp, but the trick of panelize seems easier to do.
i'll let you know
thanks
sandro
