Powder coated front panels (pics)
Holger
GDIY Supporter
Hamburg, Germany
I've already posted this in Frank's (NRGrecording) German Forum but i'd like to share it here.
Frank Röllen and me did some experiments with powder coating over the last weeks.
Edit: it wasn't me who did the powder coating, I just cooperated with a guy here in Hamburg.
The pros and cons of powder coating:
+ more durable than regular wet paint
- color tones not blendable/mixable, each color requires a dedicated powder
- some coatings are not solvent-resistant
The first prototype was more a feasabilty study:
Then we've tried some different colors and finishes (glossy/matt)
From left to right:
1. Schaeffer (blue)
Schaeffer obviously mills before coating. This results in a very bad color filling.
A bad looking panel, it was their second attempt by the way. I can not recommend that service..
More details later.
2. Grey glossy
Maybe you can see the effect that the paint comes up at the edges of the panel. My powder coating guy said that this effect can happen occasionally.
3. (Center) One of Frank's prototypes, milled out of a larger panel. Sort of Neve blue/gray
4. Yellow glossy
Full color tone, currently my favorite...
5. (Right) Yellow matt
Not as intense as the glossy version.
Schaeffer versus Frank comparison:
zayance, this was a cooperation with Frank just to make some experiences. I will clarify here that this is not my intention to step into the panel business.
It was just to show how good or bad powder coating can work. The prices for coated panel are lower than for painted panels.
Maybe you can contact Frank directly for any engraving jobs.
No i was not saying are you going to go in that business, Franck made some engraving for me, i was just curious if Franck will propose that kind of service meaning Powder coating, anyway nice pics, and nice experimenting.
Very cool stuff Holger. Thanks for sharing.  :)
I agree, the Schaeffer panel does not look very good. Franks is much more crisp.
I tell you what, the yellow really caught my eye! I think it really looks cool. My favorite too.  8)
You are right the glossy yellow looks a little better straight on. I do however not like a gloss of any kind on a panel though. As another experiment, put these in your rack and look at them from different angles like if you were tracking/mixing. The glossy panels will wash out and you can't really see anything at the right angles. The matte will not do that. I put them in my console and found this immediately.
Thanks again for the pics!
Best, Jeff
There are a number of different powder coat types. Some are for indoor use and some are for outdoor use. I don't know what that means either. Is outdoor more rugged or does the color look better under natural light?
There seem to be other differences too. Do you know what type you used? Is any type better for engraving through tan others? My emails to a manufacturer went unanswered and I haven't found anyone who knows.
I'm guessing that the stuff for outdoor use is more resistant to UV. Powder coat tends to break down and fall off after prolonged UV exposure. Some types are more prone to this than others.
The guy who did the powder coating is aircraft engineer and does some powder coating in his time off.
He usually coats motor parts, wheel rims and stuff like that.
That indicates that the coating is heat and UV resistant.
I'll ask about the powder coat manufacturer the next time I'm there.
Nice! :)
The second panel looks like a bit too much paint was applied, you could try doing just two smooth passes, starting with the powder gun not pointing at the panel, and then moving off the panel again before doing the second pass.
The outside paint type /should/ be fairly solvent resistant I think, another advantage of powder coating over painting is that you don't need a primer coat on an aluminium panel. Also, the powder paint can cover small imperfections in the surface of the metal, to an extent.
You should be able to get colours in matt versions too, or in semi-matt, and you could also try spraying a glossy panel with clear matt paint afterwards, this gives it an interesting texture as well as making it matt. There are also textured paints available, these look pretty cool but are not all that great for silk screening as the paint tends to run into the texture and the labels end up blurred, but this shouldn't be a problem when engraving.
All the best,
Dan
Just a question...
What does look better for front panels ? powder coated ? or anodized ?
Btw i have see with Schaeffer for powder coated front panel... and what u see u this picture is normal, cause they said me that if u wanna have small size engravings on powder coated panels, you have to make 2 fpd files... the first one with your powder color paint...  and the second file with your engravings (specifying you are using consumer material...)....  then u have perfect looking...
