flav
Member
First of all a big THANK YOU to Jakob and everyone else here for the passive support found on this forum.
I never have time for anything. But a few months back i started to build a GSSL. Now it's almost complete - lacks a little bit of wiring some back panel holes for the ins outs and power and a good power switch push, and hopefully the smoke won't escape from the chips and everything will work properly. after that a laser engraving of the front and rear panel will finish the job.
I did some additions besides the Expat turbo board and VU driver board. I also made a board for relay bypass and xlrs, a little control board with 3 iluminated microswitches for turbo mode, bypass and power, a custom power board - with 2 pcb mounted power trafo one for gssl and another for the relays, leds and for the last adition the led GR meter based on pico compressor's (switchable 5-10-20db) - not tested yet. For that i will post the eagle cad files when i will have the time to test it and works ok.
current state:
supply board:
microswitch board:
relay bypass ins and outs:
5db - 10db - 20db GR LED meter:
PDF AND EAGLE FILES FOR GR METER:
http://www.axaprospect.ro/electro/gssl/GRMETER.pdf
http://www.axaprospect.ro/electro/gssl/GRMETER.zip
current state:
supply board:
microswitch board:
