mylesgm
transformers for the B283
« on: July 07, 2010, 04:00:22 AM »
What transformers and/or ratios suit the b283 card?  I know that Carnhill carries a version of the original TX but is there a cheaper option or a different option?
M
Check my work at www.mylesmumford.com
briomusic
Re: transformers for the B283
« Reply #1 on: July 07, 2010, 04:18:48 AM »
because of the high DC current going through the primary you need a gapped transformer. the only alternative to carnhill that I am aware of is ed andersons version, which you will find at hairball audio on the white market. I tried the same build of a peter purpose EQN with both the carnhill and the ed anderson transformers and they both sound great.  :)
you should check if JLM do a neve type output transformer, as this would save you on shipping on these weighty buggers...
mac
« Reply #2 on: July 07, 2010, 06:44:39 AM »
Yeah Joes 111DC does the job!
"less muddy LO1166" he calls it!
unless of course it is Nv mud you are chasing!!
Mac
Barclaycon: The client said 'That sounds great, what are you using on it?'
The engineer's reply was: '30 years of experience'.
haima
« Reply #3 on: July 07, 2010, 08:02:34 AM »
hey miles  ;) - sowter and altran also do gapped models designed for this circuit. joe's do sound great though!
mylesgm
« Reply #4 on: July 07, 2010, 01:03:13 PM »
Thanks guys,  What about input?
M
mac
« Reply #5 on: July 07, 2010, 09:07:59 PM »
I know ed is working on one...
http://www.groupdiy.com/index.php?topic=28923.500
that is mic input though, not sure about line input...
Last post June 17, 2019, 04:14:30 AM
by gyraf
Last post November 16, 2006, 07:20:08 PM
by rascalseven
Last post May 24, 2009, 02:48:38 AM
by PRR
Last post August 02, 2019, 08:42:44 PM
by rascalseven
