pucho812
Was given a few older JBL amps and a crossover today. Nice stuff but it's all pin 3 hot... would changing it internally at the connector be the best way to go?
Your "polarity" flip cables should be well marked, and only used when problems arise.pucho812 said:decided to make phase flip cables.... pin 3 hot one side pin 2 hot on the other... Marked with printed heat shrink....
Only if it's unbalanced, and likely to interface with other unbalanced gear.pucho812 said:Is it even worth keeping it pin 3 hot?
SSLtech said:Only if it's unbalanced, and likely to interface with other unbalanced gear.pucho812 said:Is it even worth keeping it pin 3 hot?
Otherwise feel free to waste as much time as you like.
Keith
