Best thing would be to do a search. I'm not an expert on this at all, but I'll have two opto units coming up on the bench. Info on matching whatever type of opto for stereolinking is all scattered and seems to differ between units. Anyway, here are some thoughts:
(1) matching often seems to involve trims: in parallel to or before the LED (e.g., LA2A).
(2) 'stereolinking' the LEDs (before and after) reduces differences between L and R (i.e., D-AOC)
--> search: summing side-chains together
(3) (Forrsell only and unconfirmed, as it seems
someone suggested raising the 4.99k and 1k resistors
(series and shunt) to 49k and 10k before the opto's resistor
(here in series, see schamatic) to reduce difference between individual optos. However, a different response curve is to be expected.
(4) To match the optos themselves, I think we'd want to measure their resistances at several different current draws, plus using test signals of different durations to compare attack/release behaviour, and then compare the convex and concave parts of the plotted graphs--a process that sounds like sure headache to me... The desription of a strange thingy for Passive LDR Attenuation mentions the need for multiple optocouplers (25 or more) to find a pair that matches--more or less. I wouldn't take this info at face-value, but it gives an idea.
(5) Silvas reports (D-AOC help thread) that his input transformers created a slight difference btw. L and R. So matching starts with the periphery.
(6) I guess that for LR signals at mild levelling/compression settings we can easily get away with 'stereolinked' optos that are less than ideally matched, so a 'stereolink' switch does make sense after all (maybe rename it 'SC link'). At high settings though I expect differences to become annoying: audible shifts in stereo image/image wandering and bouncing off centre.
(7) To avoid off-centre bouncing, we could feed the unit with MS signals to 'successfully' shift differences between optos from left/right to mono/stereo...
Exhausted for now
Anyone has more ideas/better advise?
