Sammas
Where are you located? There are vendors that ship almost anywhere...Maxi22 said:Thanks, JohnRoberts.
I know this THAT-Documents.
I need the compressor not for recording, but only for talkback-mic. The problem with the THAT-schematics for me is:
it is difficult to get the IC´s.
For a compressor, you need one VCA, one RMS detector and a few opamps. For opamps, almost any generic opamp woulmd do, TL0, 5532, even 1458. VCA, the 218x is ok. Now the RMS was the 2252, but it's not produced anymore; you can probably find some from vendor's stock. But you should use a 4301/4305; are you saying the 4301 is not available for you?The 218x-family is possible, but the others are not possible / difficult to get here.
Behringer use the same chips than THAT. Years ago they used NEC chips that were the same as dbx chips, now they use THAT chips.So I´m looking for the Behringer-schematic, because there is the 074 used...
As I wrote earlier, opamps are a non-subject, what matters are the RMS and VCA.Maxi22 said:Thanks for your answer. I have found a distributor for 4301 --> mouser.com.
Are you sure - Behringer is using the same IC´s like THAT? I have opened the XENYX Q502USB. On the platine there I can find a 14-PIN-SMD-IC "074" for the compressor-section. Is this not a 4x-op-amp 071?
Maxi22
metalb00b00 said:Here's the up to date and complete Yamaha MGP mixer one knob compressor again.
Transistors are Toshiba. Either get them from eBay, or use BC/2N transistors with the same specs.
NJM4580 and NJM4565 = NE5532
1SS355 = 1N914
Easy to build, and does the job very well.
What Behringer model? Why has the schemo disappeared from your OP?Maxi22 said:@ abbey road d enter: yes, I know - a RMS is necessary... But on the Behringer-platine
These are both opamps. So, no RMS, no VCA...? It may be an opto or FET compressor.I couldn't found a special chip for RMS. There are only the 4580 an even the 074
OK, so it's an FET compressor. I don't know why the subject drifted to VCA's. The precedentlyposted Yamaha schematic should not be too different tha the Behringer's.Maxi22 said:Behringer XENYX Q502USB or XEENYX QX1002USB etc.
There are all SMD on the platine. Most of them are not marked/named. It can be, one of the transistors is an FET... There is no VCA-chip.
Yes, 074 means almost undoubtedly TL074. By today's standards, it's a general-purpose opamp, not too good in terms of noise performance.I think the named-IC "074" means a 4x-op-amp...
I had another at this schemo, and noticed a nice detail. The big issue with FET compressors is they have to operate the FET at quite a low level (typically about -30dBu) in order to keep distortion at a reasonable level; as a result, teh make-up gain stage becomes quite noisy. Here, they have put the FET in the inverting input branch, which operates the opamp at idle with a moderate noise gain, varying from 2 to 4, depending on the compression pot. When compression happens the noise gain increases, up to about 30-100, but noise is masked by signal.ruffrecords said:This bears an uncanny resemblance to my degree course final year dissertation in 1973! I built a compressor using 741 op amps which rectified both the input and output signals. The input was then passed through a piece-wise linear stage to set the compression slope and then this was compared with the output in a comparator. The comparator drove FET attenuator. The idea was the compressor slope would be independent of the FET characteristics. I will see if I can dig out the schematic.
