abechap024
[BUILD] DBX 160VU New
« on: July 31, 2010, 03:33:24 PM »
Edit: See white market thread.Thanks to all!
Hi All,
Want to let you know about a completed A Prototype PCB for the 160VU
and for those that don't know about the 160vu, I would recommend googleing it! While maybe not as much as a household name as the 1176 or SSL it is a staple studio compressor used on countless hit records. I've read it call the "Kick, Snr, and Bass compressor" also reportedly used often as a vocal compressor with great results. I say this as I've never had the opportunity to actually use one and half way through the design I was thinking to myself...do I really need ANOTHER VCA compressor? (I just finished an 8 channel ssm2120 mic/line compressor box)  but found some samples of before/after clips of the 160vu and clearly yes. I can hear why people love this compressor as they do. Seems to not really sound like anything else. Seems to have a sought after "mojo" and when dealing of things of mystics and "mojo" I have taken the liberty of not taking the liberty of changing the circuit. Original power supply and parts can be opted for throughout the PCB. I have, however, added the option for bigger power supply caps, an option for a less expensive power supply (using mnats or some other regulated supply). I've also added the option for a cheaper and easier option of a THAT VCA.
     Also, the DBX 160vu use(es/ed) a mechanically zero-centered meter. These meters cost about 150$ from DBX. If you don't want to spend as much on a meter as you probably will for the whole build, we've added a circuit the will emulate a mechanically centered meter by making it electronically centered. Thanks to Arska for coming up with the circuit and for his help with other design implements. Also thank you to DamnYankee and many others who have helped with information and ideas!
this PCB includes:
-All transistors changed to modern counterparts, so no hard to source components!
-Ability to use a THAT 2180 VCA, a DBX 200 can VCA, or build a discrete 200 vca right on the PCB
-Ability to use a DBX RMS detector can, or build the RMS unit right on the PCB
-Completely original power supply. Plus an option to easily patch in a different power supply if you wish
     This is a "Prototype" Small batch PCB feeler thread. If you want to build one, but aren't very experienced with electronics, or are scared of a possible challenge this probably isn't for you. You might as well wait for the "Final" Revision to come out in a couple months.
     But for those of you who are itching for your very own 160vu and are excited about electronics and have the equipment and tools for a possible troubleshooting shootout or two. This is your ticket.
     I don't *for see* many problems at all. I've been working on this for about a month and have checked the schematic many many times. Also checked and rechecked for the RMS/VCA circuits. But there always seems to be something; mainly I want to see what components are available to people outside of the US, and if there are any recommendations on footprints or any other of a million things that could be changed for easier building/implementation.
Also I haven't been able to get my hands on any original vca/rmc modules and no one has made the measurements available, so I've been forced to resort to black magic and tom foolery, The dimensions should be correct, but I have no way to verify this so This is another thing that needs to be confirmed before "Final" revision.
Prototypes will be 35$ shipped to anywhere in the world. we will need at least 10 people to place an order.
Here is the Schematic and the TOP of the PCB with DBX module pin outs in case anyone can confirm spacings...
www.acsoundstudio.com/DIY/160vu/schematic.jpg
www.acsoundstudio.com/DIY/160vu/PCB1.jpg
Thank You,
Abe
« Last Edit: May 03, 2011, 02:25:22 AM by abechap024 »
AC Sound - some DIY circuitboards
Biasrocks
Re: Feeler: 160VU PCB
« Reply #1 on: July 31, 2010, 03:49:08 PM »
Cool, I'm in for one.
I've got a 119 that I'll sacrifice to test out the real deal RMS/VCA combination.
Mark
http://SharktankPro.com
"I'd rather use an SPX90 than a UA plugin....." Joe Barresi
3nity
« Reply #2 on: July 31, 2010, 04:13:37 PM »
Really excited for you Abe...and i really wish you good luck.
Altough offer protos is kinda of crawling in the dark...
If unit works 100% im in!
Life is a path, death the destination.
Arno
« Reply #3 on: July 31, 2010, 04:47:33 PM »
I might be in for 1.
zayance
« Reply #4 on: July 31, 2010, 05:56:46 PM »
 8)
abechap024
« Reply #5 on: July 31, 2010, 07:51:49 PM »
Thanks you for the interest so far.
     And your right 3nity, having the option for people to buy prototype PCBs isn't really done that often around here...But I feel the more people we get involved on this small fabrication the more ideas we'll have for the final bigger batch of PCBs. I wish I could promise you 100% functionality, but as It hasn't been tested yet I cannot. But all circuits must be tested at some point. I am very confident they will work and offing these prototypes is just a step to make a better and easier final product.
    These PCBs are mainly for people that want to have some input and be the first few to have the 160vu. I cannot make any 100% guarantees they will work, but also I offer you the challenge to find any reason they will not work! This is DIY after all, and here's your chance to offer some input on the final run of PCBs.
Abe
pedroplanet
« Reply #6 on: July 31, 2010, 08:47:24 PM »
I'm in for 1
dustbro
« Reply #7 on: August 01, 2010, 01:26:32 AM »
Id give it a try... should be fun
lsskmki
« Reply #8 on: August 01, 2010, 01:01:49 PM »
Ok, one for me please :)
abechap024
Re: Payment: 160VU PCB Prototype
« Reply #9 on: August 02, 2010, 08:27:00 PM »
Just a bump of good news. We have enough people interested to go thru with the order! See first post, I edited it, then realized that doesn't push it to that top. so here it is....
paypal: [email protected] 35$
Ans if you want to order a prototype go ahead and send payment, its not too late
Thanks All!
abechap024
« Reply #10 on: August 03, 2010, 12:26:49 AM »
Cool. confirming Payment: dust bro
kml23956
« Reply #11 on: August 03, 2010, 01:03:01 AM »
Sent the money for 1 board.
Music is for kids:
Sredna
« Reply #12 on: August 03, 2010, 09:31:29 AM »
Paid for one board!  ;D
Anders
Hmm... in which direction do the electrons actually go?
abechap024
« Reply #13 on: August 03, 2010, 11:04:43 AM »
Anders
Hi Conforming Payment for:
Lassi
Suttle
Anders
envelope
« Reply #14 on: August 03, 2010, 01:22:16 PM »
Hello, I would love to test one of the prototypes, can I get in on this first order? Stuart Whitby.
abechap024
« Reply #15 on: August 03, 2010, 01:42:58 PM »
Hi Stuart and anyone else interested in ordering a prototype pcb,
The order is still open. [email protected] for 35$ and you get one. The more we have the better.
Thank you!
AC
Arno
« Reply #16 on: August 03, 2010, 04:54:53 PM »
payment made for 1
thanks!
abechap024
« Reply #17 on: August 03, 2010, 05:06:36 PM »
payment made for 1
thanks!
Confirmed, thanks Arno!
envelope
« Reply #18 on: August 03, 2010, 05:33:06 PM »
Payment has been issued for 1 pcb. thanks for the efforts, should be fun.
Soeren_DK
« Reply #19 on: August 03, 2010, 06:33:18 PM »
Abe
Thats great thinking.  ;) ;) ;) Thumbs up here from Denmark....
Søren
Quote from: idylldon
...it works like a champ and is as quiet as a mouse pissing on a cotton ball.
http://www.soundcloud.com/doctorsclub
Last post November 24, 2004, 11:41:13 AM
by
Last post June 28, 2005, 07:11:20 PM
by OddHarmonic
Last post January 10, 2019, 12:34:56 PM
by Rob Flinn
Last post October 22, 2020, 03:56:57 PM
by znjamznjam
