living sounds
I've got an MXL 2006 which I've modded extensively before (upgraded caps, FET, grill) and now put in one of Dale's C800 capsules. It sounds great now, very bright and clear but without the nastyness. However, there seems to be a high end roll off which I'd like to modify, and maybe the high pass filtering as well.
I read that the circuit of the 2006 is supposed to be identical to the 1006. It should be based on the Schoeps circuit, it's transformerless. I've searched, but couldn't come up with the schematics. Does someone happen to know where I can find it (MXL, not the Schoeps)? Also, does anyone know the polarisation voltage generated? I can't measure it properly with my multimeter because of drainage.
