Hello all,
Could not find any connectors here in my country and so i decided to DIY - hope it will last for sometime till i figure out a way to make a better one or get one without spending much $$$.
The Connector is made of cut-out cable sleeve with the Female XLR pins inserted in it. The pins had to be stretched to fit the bigger male pins on the STC mic.
Here are the pics that i would like to share.
Inside View of the STC 4038
First test...without any proper connector...using cable clips
DIY Connector Cable View 1
DIY Connector Cable View 2
Connection
Full Setup with the DIY Elastic Mic Sling
Connection
