dagoose
I made some progress with my 3u stepped sontec and before i go on holiday i wanted to post some pics of this beast.
All pots are stepped switches so i soldered over 700 point2point resistors. 8)
The frequencies and gain are scary precise and totally matches the frontpanel engraving.
The frontpanel was done by Pete / grandmaster audio which is really a cool guy BTW, he even thought me some new english phrases. ;D
The filterboards (igor's) where cut in 4 parts leaving 1 'big' board for the mid range, 2x for low end and 1x for hi shelf. It takes some extra wiring to have things running but it works like a charm!
All bands have a 6/off/12 db switch for gain with led (green=6db off=no led red=12db)
I'm waiting for the Forsell 993 DOA's to come in for the output but opa604's work fine for now.
Things to do for now:
* Fix one band of the left channel, it doesn't do anything, 2604 is ok, probably cold soldering (leadfree..).
* Finish the right channel.
* Crank in the DOA's.
* Clean up the wiring
* Enjoy the looks and sound. :-*
More info and better pics after my holiday. :
