dagoose
correct! I'd like to keep the wires as short as possible.radiance said:Nice! Why did you cut the boards? Shorter wires maybe?
If i used the boards as they are it would make it quite a lot of wiring mes since the boards are for a 19 inch long panel and because of this panel it had to be half of that. Cutting it in even more pieces made even more sense, if you look at the bare board you can see it's really easy to chop the bands.
