RedNoise
LEM audio transformer questions
« on: August 30, 2010, 12:16:04 PM »
Hi all !
I just bought a couple of LEM T.2610.
I have absolutely no idea what they are for , nor their specs.
A quick search did not match any results.
Do anyone know them?Their specs?Their quality?
Could someone tell me if I can measure the "coils" with a DMM ? (I only have a FLUKE 117 in my hands)
Maybe a rough idea of their unit price ? (I think I'll sell them)
Here's a pic!
Uploaded with ImageShack.us
If your neighbour is hunger : don't give him fish , teach him how to fish ...
if you don't like it don't buy it ;-)  [Wolker Texas Ranger] ( ;-) )
abbey road d enfer
Re: LEM audio transformer questions
« Reply #1 on: August 30, 2010, 01:46:04 PM »
http://www.lemindus.com/contact.php
They used to make a number of OEM products. Maybe they still have some info...
RedNoise
« Reply #2 on: August 30, 2010, 02:05:27 PM »
WOW!!!
Merci beaucoup!
RedNoise
« Reply #3 on: August 30, 2010, 02:13:50 PM »
I measured : (approx)
25R between 1&2 , 25R between 2&3 , 46R between 1&3 , 26R between 4&6
Could an expert translate tho results for me ?.
I'll give a call to LEM tommorow!
Thanks.
ioaudio
« Reply #4 on: August 30, 2010, 05:10:18 PM »
Could be a nice choice for a pultec input transformer or other 600Ohm to 600 Ohm app.
Primary is 4&6 and secondary 1&3, ommit the center tap 2, connect 5 to shield/ground.
-max
edit: sry, miss - read the 26R between 4&6 as 46R
« Last Edit: August 31, 2010, 06:56:06 AM by ioaudio »
RedNoise
« Reply #5 on: August 31, 2010, 02:09:28 AM »
Hi Max !
Then I'll try it in my meq500 ! Thank you so much for your explanations.I was quite sure they were 600/600 as I "think" they were used just to prevent from buzz  ...
Mathematical question : how can I know they are 600/600 whereas primary measured 25 and secondary 45 (R) ??
Is there a secret formule that a tx genius would share ? ;D
So , who have an idea of a fair price ?(fair for buyer and fair for seller) :)
« Last Edit: August 31, 2010, 02:11:30 AM by RedNoise »
audioforge
« Reply #6 on: August 31, 2010, 06:02:10 AM »
google for websites " eg http://www.diyguitarist.com/GuitarAmps/OT-ReflectedLoad.htm
feed some voltage thru the primary and measure the voltage on the secondary.
you will have the impedance ratio.
if your voltage is equal you have a 1/1 transformer.
you can use it as 600/600 but also 200/200 10k/10k etc.....
to know if it s a good tx used as 600/600 you need an oscillo and a generator.
just put a 600 ohm R across the secondary and your oscillo probes here.
send a signal (sinus then square) from 20 hz to 20 40 100khz (-20 -10 0 + 10 +20 db)and look at the wave form on your oscillo.
hope it help
audioforge
ioaudio
« Reply #7 on: August 31, 2010, 06:59:16 AM »
sry, i miss-read the value between 4&6.
to hook up as 1:1 connect pin (1+3)&2 as primary.
RedNoise
« Reply #8 on: August 31, 2010, 11:14:04 AM »
Thank you guyzzz!!!!
I called LEM today , will send them an email , and then will wait for the answer...
But for my own knowledge I'll try to get an oscillo and try Audioforge's technic!!Thank you again !
T.
PS : Audioforge , I'm "specone" @ audiofanzine...Cheers!
RedNoise
« Reply #9 on: August 31, 2010, 11:15:58 AM »
Less strange to me then!  :)
They effectively were connected like this before I pulled them out of their rack.
tofufo7
« Reply #10 on: April 22, 2020, 09:56:37 AM »
Hi everybody, back to this topic, sorry!
Would like to know if anybody has seen that kind of transformer. I think it should be an input transformer...
Thank you
Last post November 12, 2005, 09:14:12 AM
by maxime
Last post April 17, 2010, 06:11:11 AM
by chile
Last post April 27, 2020, 05:57:34 PM
by ruffrecords
Last post April 25, 2020, 12:28:10 AM
by JohnRoberts
