intergalactic
Member
- Joined
- Aug 22, 2010
- Messages
- 10
Ptownkid said:This would be the perfect time to learn how to create your own library part. I can't believe how many errors I've found in "stock" eagle libs. I pretty much make everything myself now.
signalflow said:Search for CK101X12 in your library. It has the 30deg angle that your CTS switch does. The only thing that might be weird is where the pole solder point is located. At which point I don't know how set on that switch you are but 10SM159 from mouser should fit that foot print and it's cheaper.
I'm not sure I understand your right angle question/typed thought process. If your switch is board mounted why would you mount your XLR jacks at a right angle? Maybe I'm misunderstanding, which happen quite regularly.
-Casey
intergalactic said:signalflow said:Search for CK101X12 in your library. It has the 30deg angle that your CTS switch does. The only thing that might be weird is where the pole solder point is located. At which point I don't know how set on that switch you are but 10SM159 from mouser should fit that foot print and it's cheaper.
-Casey
do you recall which library it is in? It didn't show in my Eagle 5.10 library search.
