thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
I am feeding a network of LC filters (input impedance of 600R) from an op-amp, wired in an inverting config as a summing amp. There are 50k pots, feeding 47k summing resistors - into an op-amp with a 47k FB resistor.
The problem is that the LC network saturates easily, creating a nasty odd harmonic spike (I've proven this in isolation, so it's not the preceding op-amp). Therefore, I need to attenuate the level by around 10dB. I have experimented with an FFT and know this works perfectly, with a decent overall THD figure, albeit a compromise on SNR.
So...what do you think is the best way to lose this 10dB? I've tried putting a 600R L-pad in front of the LC network and it messes with the FR - creating a spike in the 250-ish region, and HF roll-off (about 1.5dB by 20k).
An easy way is to simply increase feedback. However, this will change the overall IP impedance of the summing amp, and I'm feeding it with 50k pots which can't be changed.
TIA
Justin
TIA
Justin
