6bc8 plate balance in UA175 and Altec/RS124?
« on: September 12, 2010, 12:53:30 AM »
Trying to figure out the 'Neon bulb balancing trick' used on EMI Altecs. You guys have pulled through so far for me, hopefully this wont be very hard to find an answer to.  ;)
The UA175 and EMI/Altec both had plate balance on the 6BC8, but the EMI used a neon bulb to create a ticking that was canceled out when perfectly balanced.
Here is a more through explanation by someone on GS:
"As i understand from "Recording The Beatles", the Balance was a way to synchronize the two amplifiers in the "push/pull" design of the RS124. it was done with a neon Bulb that was wired to the circuit, when the technician pushed the momentary switch (the one you called balance button) the bulb would create a repetitive low frequency "ticking" sound. the sound was sent through both amplifiers. since one was in reverse phase the two amplifiers would null if they were perfectly balanced.
but if you could hear the " tickling" noise you knew the amplifiers were not properly balance. in that case you could adjust the amplifiers balance with the screw hole in the upper left corner above the balance. "
Anyone have an electrical explanation, or know any similar applications I can look at to see exactly how this was implemented?
rotheu
Re: 6bc8 plate balance in UA175 and Altec/RS124?
« Reply #1 on: September 12, 2010, 01:39:59 AM »
Look in the Lab for "Another Poor Man's Fairchild 660/670", on the page 12 there is a power supply and balance circuit schematic. This balance circuit is the one from EMI RS-124. Ignore the DPDT switch and double output, that's for two channels. Just use SPST switch.
« Reply #2 on: September 12, 2010, 09:01:13 AM »
Beautiful, and thank you! Looks just as simple as I expected.
Your PM670 looks GREAT btw.
gary o
« Reply #3 on: September 15, 2010, 06:55:42 AM »
Hi Ed, I built a RCA BA6A a while back it has a built in circuit that basically puts 6.3 VAC thru the input and out to the meter for you to adjust with the balance pots......I had to change my version a little so that i hear the hum and can adjust by ear.....its works great....so is similar to RS124.
I believe the BA6A schematic is in the metas if you want a look
heres a relaxation osc prob similar to wot they used on RS124 either ways its only used to balance circuit has nothin to do with sound...
http://www.cliftonlaboratories.com/relaxation_oscillator.htm
eskimo
« Reply #4 on: September 15, 2010, 12:35:22 PM »
More specifics on that? Schem? Sounds interesting.
gary o
« Reply #5 on: September 15, 2010, 08:20:04 PM »
http://www.sowter.co.uk/schematics/rca_ba6a.jpg
this schematics has some wrong resistor values
http://www.groupdiy.com/index.php?topic=4570
Theres more info if you search for BA6A I think some 1 has made one recently too it was thanks to CJs work and my money that Sowter make the transformer
eskimo
« Reply #6 on: September 15, 2010, 08:56:18 PM »
Oh, I meant your balance hum introducer. :)
gary o
« Reply #7 on: October 08, 2010, 09:55:23 PM »
The hum inducer from the BA6A ?..........if so its in the schematic.. basically 6.3 VAC....
Last post November 17, 2009, 04:20:15 AM
by syn
Last post October 11, 2010, 12:12:36 PM
by EmRR
Last post February 02, 2021, 06:56:08 AM
by Winston O'Boogie
Last post April 29, 2020, 08:11:20 PM
by EmRR
