Harpo
Re: SB4000 Support Thread
« Reply #1500 on: September 02, 2019, 02:42:06 PM »
All the links online are all dead.
Link at reply #1285 from pg.65 seems to be working ?
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.  -Douglas Adams
Blackdawg
« Reply #1501 on: December 01, 2019, 03:05:56 AM »
Can someone please upload the SB4000 schematic.
I need to know resistor / jmp values for the dbx202c gold can VCAs.
I posted it literally 9 posts before yours..
« Reply #1502 on: December 08, 2019, 02:40:20 PM »
Im using the Hairball meter, and for some reason just turning the threshold knob makes it jump. It'll pin, then settle back down. Ive check the feed pins from the pcb and it looks there is DC voltage going to the meter when I turn the knob. It'll go up 3 volts and settle back down. Any ideas?
P&P Sound Studio
« Reply #1503 on: January 17, 2020, 02:39:09 PM »
Im guessing I must be the last guy to build one of these, this thread seems pretty dead.
P&P Sound Studio
« Reply #1504 on: January 20, 2020, 02:23:03 PM »
:bump:
P&P Sound Studio
« Reply #1505 on: January 27, 2020, 08:21:34 AM »
I built one a few months ago. It's a beast, love it
« Reply #1506 on: January 30, 2020, 04:25:21 PM »
Hello... lo... lo... lo...lo
P&P Sound Studio
« Reply #1507 on: February 09, 2020, 04:02:36 PM »
I'll try again. At R111 I get a voltage spike of around -3 Volts, it starts to bleed down to 0 and then spikes again. It happens roughly every 3 seconds, like a clock. Any suggestions where to look?
Also, only seems to happen when the control board is plugged in. All the connections are good, and I dont see any problems with component orientation.
« Last Edit: February 09, 2020, 05:15:18 PM by Chrome Heart »
P&P Sound Studio
« Reply #1508 on: February 10, 2020, 02:36:51 PM »
Well, it looks like the jumper at R169 is the culprit. I put in the 47K resistor and it seems to have eliminated the problem, however Im not getting as much throw on the threshold as before. Any ideas?
P&P Sound Studio
« Reply #1509 on: February 10, 2020, 05:21:43 PM »
After I first built the unit I tested and calibrated using a Behringer style round meter. I didnt start experiencing the weird stuff untill I swapped in the Hairball meter.
P&P Sound Studio
JMan
« Reply #1510 on: February 11, 2020, 10:19:11 AM »
I’m still building this project. I got in on this late, so I’m just finishing up stuffing my boards.  I also have some pretty basic questions.
First off, and I think there may have been some earlier discussion of this, but I can’t seem to find it now: has anyone got a good way of mounting the transformer without having that awful bolt head on the underside of the case?
Second, with regards to the trim pots, are there pre-trim values for all of them? I think I located all of the values listed on the schematic, but that doesn’t cover every trim pot on the board.  Are the others purely for adjustment after the fact and don’t need to be pre-trimmed?  (I think I did a bad job of wording this question, but I imagine you will understand what I’m asking).
« Reply #1511 on: February 11, 2020, 12:04:41 PM »
If you bought the kit. the trimmers in the VUDriver circuit have been replaced with resistors. Except for VR15, which is the Bargraph adjustment.  Replaced trimmers are VR11, VR12, VR13 and VR14.
« Last Edit: February 11, 2020, 12:14:23 PM by Chrome Heart »
P&P Sound Studio
« Reply #1512 on: February 12, 2020, 09:29:21 PM »
I soldered the bolt inside the case, no problems at all. Just try not to over do it when soldering or you will make a hole in the case.
« Reply #1513 on: February 12, 2020, 09:33:53 PM »
I can't calibrate my VU meter properly. It's getting the signal too loud and I can't turn it down using Vr15. I bought the kit with the resistors instead of the trimmers. Any ideas on how i can fix this? Thanks
« Reply #1514 on: February 12, 2020, 10:38:04 PM »
which meter? Reduction or bargraph?
P&P Sound Studio
« Reply #1515 on: February 13, 2020, 06:19:37 AM »
The bargraph
« Reply #1516 on: February 13, 2020, 07:37:06 AM »
The bargraph
Make sure the bargraph isn’t installed upside down.
P&P Sound Studio
« Reply #1517 on: February 13, 2020, 07:46:36 AM »
It works as it should but the input signal to the meter is too loud. It's installed properly. The only thing I need is to reduce the input signal to the meter, maybe the calibration pot needs a higher resistance?
« Reply #1518 on: February 13, 2020, 08:08:34 AM »
It shouldn't,  unless the wrong value is currently installed. Are you sure the test signal is 1.228vac?
P&P Sound Studio
JMan
« Reply #1519 on: February 14, 2020, 05:18:03 PM »
Yes, I see that the parts kit provides fixed resistors in the bargraph driver circuit with an option to use trim pots for fine adjustment.  I’m putting in trim pots there just cause I have them.  Will set them to the values of the fixed resistors and hopefully won’t need to touch them again.
Still, any info on actual pre trim values elsewhere on the board?  Here’s what I was able to grab from the schematic:
VR7 - 6k4
VR8 - 6k4
VR15 - 10k
VR16 - 6k (is this right? It’s a 50k pot, why such a high value pot with such a low pre trim value?)
VR17 - 2k
That still leaves a bunch of trim pots, and I am not sure if they need to be set to any particular values before putting them on the board.  Any help?
Last post August 02, 2020, 08:15:57 AM
by ipindalieson
Last post April 22, 2020, 05:13:06 PM
by Hairball Audio
Last post January 09, 2020, 04:17:23 PM
by tron23
Last post June 20, 2013, 01:09:53 AM
by Fubard
