ewlewl
dbx 900 series rack ?
« on: September 15, 2010, 11:33:26 PM »
 Does anyone know if i can use the this power frame and install the 312 api mic pre from classis audio products . will the pin outs work etc. thanks
Biasrocks
Re: dbx 900 series rack ?
« Reply #1 on: September 16, 2010, 12:00:36 AM »
Ah, no.
500 Series Pinout Data
Pin     Description
1.    CHASSIS
2.    Plus 4 Output “+”
3.    option
4.    Plus 4 Output “-”
5.    Audio Ground
6.    525 Stereo Link
7.    option
8.    Plus 4 “-” Input
9.    option
10.    Plus 4 “+” Input
11.    Gain Adj 550b, 560b
12.    +16 volts DC
13.    Power Ground
14.    -16 volts DC
15.    Phantom +48 VDC
The “basic” API 500 Series pinout. “Option” implies some vintage and module-specific variations.
Mark
« Last Edit: September 16, 2010, 12:02:21 AM by Biasrocks »
http://SharktankPro.com
"I'd rather use an SPX90 than a UA plugin....." Joe Barresi
shabtek
« Reply #2 on: September 16, 2010, 12:12:20 AM »
you could cobble in an adaptor, methinks.
those dbx cards are about 4"deeper than the 500 format cards
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
ewlewl
« Reply #3 on: September 16, 2010, 12:22:32 AM »
Hey  guys Thanks for the replys ..got any specifics on how cobble in a workaround? the unit i have has 4 903 comps plus 4 904 gates and a 903 de-esser  rarely ever use the gates or de-esser .just thinking about ordering a couple of the 312 mic pres . trying to figure out a way to use without ordering a 500 frame
« Reply #4 on: September 16, 2010, 10:14:03 AM »
Find out the pinout for your aphex box's edge connector, buy a 30 Pin Card Edge Connector and a 51x Card Edge Proto PCB Adapter from Classic Audio Products of Illinois.  Then all you need to do is "connect the dots" between the api pinout that Mark gave you and the aphex pinout so that your ins, outs, power, and grounds all get to where they need to be.  Does your Aphex box have 48V?  If not, that might be something you'll want to consider adding.
ben
ewlewl
« Reply #5 on: September 16, 2010, 11:50:47 PM »
THANKS
DBX 900 rack
Started by Unbound « 1 2 » Drawing Board
Last post August 26, 2008, 01:26:32 PM
by sahib
Last post June 08, 2005, 03:54:21 PM
by SSLtech
Last post May 09, 2011, 05:24:40 PM
by moamps
Last post February 22, 2012, 03:31:25 PM
by Dubka
