Headphone amp
strangeandbouncy
West Sussex. UK
  I've been looking at headphone amps. Someone recommended the Grado ra 1. It is Cmoy, or summink like that . . . .
  what i don't get is this. It is ok for 32 Ohm headphones(apparently). How the f@@k can a JR4556(just an ordinary op-amp. no?) possibly drive 32 Ohms??????
    much puzzled,
      ANdyP
I could not locate the data sheet as it comes up as obsolete but it will drive. I have tons of headphone amp modules removed from pro broadcast equipment with cheap JR opamps. If you want to fiddle about pm me your address and I'll send you a couple.
No. Look it up.
It is the good-old 4558 but with a fat 70mA output stage (and cleaner processing than early 4558s...).
The chip is still available... but the company is trying to change its name away from "radio" and (stupidly) changed their part-numbers.
Look for NJM4556
http://www.datasheetarchive.com/NJM4556-datasheet.html
http://www.datasheetarchive.com/pdf/getfile.php?dir=Datasheets-22&file=DSA-438447.pdf
http://www.datasheetarchive.com/pdf/getfile.php?dir=Datasheets-110&file=DSAP00646.pdf
Hi PRR,
  thanks for your reply and links. Datsheet quotes that it will drive 150 Ohms. That is a lot greater than 32 Ohms! I guess that that figure is at full power(?) Surely running into a lower load will compromise the distortion performance, even at lower power(?)
    I think that I should break out some of my spare 2520's or OA10's for headphone application . . . . plenty of grunt there
    Kindest regards,
    ANdyP
Forgot to add, the best headphone amp (by miles) is made by Texas Instruments, the TPA6120.
This implementation is damn good, just ignore the PSU bits of the circuit.
http://sjostromaudio.com/joomla/index.php?option=com_frontpage&Itemid=1
http://sjostromaudio.com/joomla/index.php?option=com_content&task=view&id=43&Itemid=27
Frank
Grado RA1 uses a LM386s, those are power amps in a dip8 package. Not sure how well they sound, but that Grado amp is pretty well regarded I think.
CMOY uses a dual opamp in parallel per channel, will not cut it for your 32ohms Grado headphones.
I use a super simple headphone amp for my Grados, based on the Szekeres (google). It's a IRF610 fet with a LM317 as it's current source, class A, sounds fine.
0dbfs said:
Thoughts about using the LM4765T to drive headphones?
http://www.national.com/ds/LM/LM4765.pdf
jonathan
You really want to use 30+ watts on headphones????
Here in the UK, we would call you a screaming nutter.
Frank
Frank
Ha!
Well, we used to use 75 or 150 watt crown amps with a passive cue box like this:
www.skeng.com/Simon_Systems_files/CB_4.pdf
:-X
It sounded pretty good.
So, a 30W driver doesn't sound unreasonable based on that.
This part is about $7.5 from digikey and with an input-buffer->10k-pot->buffer->amp you could use a wall-wart to power it all.
j
In the first schematic in this thread I don't see a series output resistor to keep the amp stable into different loads.  Opamps that are connected to unknown loads can oscillate.  Length of cable adds capacitance and the drivers inductance.
I also see something else I question.  Anyone want to guess?
HI Guys,
  I guess the schemo might not be accurate then, LM386 'n all . . . .
  Sahib, thousand pardons, I somehow missed your kind offer. I would love to try 'em out, yes please! PM on it's way.
  Thanks for all your replies. I will look into the szekeres idea. Looks interesting!
  Kindest regards,
      AN dyP
found this
http://www.ecp.cc/ra1.html
http://www.parttimeprojects.com/audio/diy/CMoy%20Headphone%20Amplifier.php
What I would do is use a 100Lin with a 20/22K input to ground for the 100K and I would scale down the feedback resistors so the || value was about 20/22K.
I would guess most things that would drive this circuit could drive 100K|| 20/22K.  The 20/22K will adjust the volume control curve and the lower value resistors will case a little lower noise.  I would also add a 10 Ohm series output resistor.
A 386, really?
What about current drive with the headphone driver as part of the feedback?
I have PCBs for Headphone AMP. I have copied the circuit from my Alesis X2 Desk. Circuit is good & sound nice.
Regards
Dinesh
