Rob Flinn
I have searched the forum for posts regarding what I am about to say & didn’t really find a solution/answer. I may be raking up something that has been covered before. If there is something to be read please point me in the right direction. I have read about the 12AY& & 100k anode resisitor mod.
Anyhow possibly a silly mistake on my part, but here goes :
Over the years I have made a few La2a replicas, 2 that are point to point & 2 using the drip version 1 board. Several people have used them over the years that are very experienced using different original vintage versions have said that for normal operation they have the gain control set to around 11-12 o’clock, whereas on all of my replicas it is more in the 8-9 o’clock range. I have also been told that the Bloo versions behave like the original in this respect. To be a bit more specific this is if I inject a +4dB signal into one of my La2a’s & switch the meter into the +4dB range, & then adjust the Gain control so I get a zero reading on the la2a meter. THIS IS WITH NO COMPRESSION HAPPENING. Can anyone verify how their original or replica behaves in this respect ?
Recently I had the opportunity to compare one of the drip versions (using Sowter 1009/4383 combination) against a vintage version & found that this discrepancy was indeed the case. The vintage unit had a T4b with 3 ldr’s, but I have swapped that with one of my UREI t4b’s & the response was the same. These particular Sowters are supposed to be near replicas of the A10/A24 (& sound really good by the way).
All of my La 2a’s use real UREI t4b’s They use log pots for gain & peak reduction. The components are the values as on the diagram labelled C-10953 C. With regards to transformers I have several different combinations
In Out
Sowter 1009 Sowter 4383
Gardeners Sowter 8940
Parmeko Sowter 8940
UTC A10 Parmeko
It is fair to say that the versions with Gardeners & Parmeko input transformers have the Gain control slightly higher, but they have lower ratios, which would account for the difference.
Unlike most people I DON’T want to reduce the gain of the compressors particularly, so the 12AY7 & 100k anode resistors mod isn’t something that I want to do particularly.
I do like the sounds of all of these compressor, & they are all slightly different, & ultimately that is what is important, but I’m puzzled by this difference, & just wondered if anyone had a handle why I’m getting a difference, because I’m scratching my head now ?
Any thoughts would be appreciated
In Out
Parmeko Sowter 8940
UTC A10 Parmeko
