abbey road d enfer
Re: Which Capacitors for Audio?
« Reply #40 on: November 09, 2018, 06:51:14 AM »
I measured it.
How? Measuring ESR takes some specialised equipment and thorough metrologic methods.
Who's right or wrong is irrelevant. What matters is what's right or wrong.
Star ground is for electricians.
jensenmann
« Reply #41 on: November 09, 2018, 07:12:11 AM »
I have an ESR meter and a cheapish component tester which does ESR as well.
But as you beat me to it  I quickly took some measurements of a few Wima MKS2 6,8uF and they were all around 0,4 Ohm. I have no 10uF here at the moment.
But I remember very well the bag of 10uF Wimas I measured and all were around 17 Ohm. I remember it because the value was so high. That made me think that they are all in the same ballpark. Obviously a bad batch. I stand corrected. Good to know....
Jens
Quote from: PRR
The tubes of course don't care what frequency they distort
scott2000
« Reply #42 on: November 09, 2018, 07:27:45 AM »
So does this mean these film/foil /wima caps are in fact good to use for power supply bypassing??
rackmonkey
« Reply #43 on: November 09, 2018, 09:52:57 AM »
over dozens of measurements, I see just the opposite. That’s in line with the datasheets that are available also.
Whether you think you can or you think you can't, you're probably right.
Last post August 11, 2004, 03:02:27 AM
by matthias
Last post May 08, 2005, 05:14:26 PM
by PatinaCreme
Last post July 20, 2006, 12:00:14 PM
by mr coffee
Last post November 20, 2009, 05:18:32 PM
by jdbakker
