mkruger
For some reason I am getting noise, but not always. It's a solid state preamp. Some times when I turn it on it will have a lot of RFI and noise coming through. Then other times it won't. Even if nothing has been changed, same cables, input, signal flow... It's definitely the preamp.
Volume doesn't affect the level of the noise. So it's either after the attenuation stage or in the power supply. What do you think?
