North American G9 Transformers
First check out just the power section on this page at the bottom of the schematic
www.gyraf.dk/gy_pd/g9/g9_sch.gif
Then download this page and look at it?.for a long time!
www.nrgrecording.de/Gyraf_G9_trafos.pdf right click save as
The PDF File from nrgrecording is for 220V application, North American 110V transformers will have two primaries.
Get your PCB overlay or stuffing guide and map out your intentions for hook up.
*****Note, You must read this first.*****
This reference is using the Hammond 182J15 transformer wire color codes and no other transformer is implied. You must acquire the manufacturer?s color code chart to find out primary secondary match ups.
This is the dangerous part of DIY because power is showing up in you project. We all want success at this point not smoke. Read read and read more on this topic. Keep you hands out for power up.
Both transformers should have two primaries and two secondary windings. Or eight wires. Hammond or Avmeco part numbers listed for the G9 will work. Find out from the manufacturer which wires match up primary to secondary. Then start connecting.
PCB is referenced looking at the board with the two relays at the top left so put it on your bench like that now.
1 . If you are using the common PCB for the G9 the first transformer will be connected with both primaries Blk/Brn together at one terminal and Wht /Orn to the other terminal as mains negative and positive. This must be have a fuse, 1AT is listed on the schematic( I think that is the fuse). Imagine your transformer is now two(2) transformers.
2. The secondary windings will go as follows; one secondary Red and Blu to the 15VAC/1A (above D17) and the other secondary Gry and Yel is connected to the other 15v terminal(beside C23). You now have 15 volts attached to the board in two places.
The first transformer steps 110V down to two(2) 15VAC sources.
Next
3. Then attach the other transformers secondary, yes secondary windings to this same spot below C23 so that you will again have two transformers. So now Gry/Red attached together to one terminal and Blu/Yel attached together on the other. Again you now have two(2) transformers. Just imagine it ok!
4. The Primary windings on the other end must be attached as follows. One black lead to the 220Vac connector above D17, the white and brown wires are tied or soldered or welded or crimped together, Then the orange wire is attached at the terminal point above D17.
Now you have two power input windings pushing one big power output winding. In essence your 15V is now 220 volts.
You are now Dangerous as far as voltage and current are concerned.
I do recommend as you may have seen on other G9 projects the use of a terminal board for your wire attachment points.
Notes I have found on this topic are many from general to specific. Some from Jacob, Kev and question forums with answers. If you want more information PM me with questions. I have not completed this project. I am waiting for a replacement transformer, one winding is open on one primary. So wait a couple of days for my part to come in so I can test and confirm all of this. I have notes from others that reference all I have written but still approach with caution.
If I'm out to lunch on any of this, please correct me.
Hope this makes things more clear. I will draw up an attachment guide as soon as I have more time.
