You guys are laughing at me don't you , ;-)I was just guessing this because of HZ1 HZ2 etc etc..
now I am really excited! I'll be in for 3 if a more detailed rendering is posted.seriously , I was guessing headphone distro amp.
I think it is the QHZPIC51XbMF
Quote from: pacemaker on October 08, 2010, 05:15:24 AMYou guys are laughing at me don't you , ;-)I was just guessing this because of HZ1 HZ2 etc etc..Well, if it makes you feel better, you were right about the Hi-Z plugins!It's a 500/51X series recording DI box essentially. It's meant to be placed between a microphone and a preamp.It uses the Classic API and [silent:arts] Hi-Z plugin format. There are four 1/4" inputs for four Hi-Z plugins. The inputs have a priority system in place so that there can never be two active inputs at a time. The logic circuit also makes sure that the microphone signal gets fed right through to the preamp when no instruments are plugged in to the front panel.There are also two switches:- The first one is a MIC input selector (DI defeat).- The second one is a DI output pad.What do you guys think?
Quote from: [silent:arts] on October 08, 2010, 04:42:44 AMI think it is the QHZPIC51XbMF And what exactly would THAT be??? lol
Excellent Volker' !!And mike very good job !A multi DI is a very good project,But i think i would have prefered One input and switchable different audio path, so as you can plug your instrument and compare circuitsin order to choose the best, But it's also possible to unplug and replug ,Anyway, congrats on this new 51X baby !The family become bigeger and bigger !Regards,Francois
a good speaker [ & mic ] simulator would be a featI keep trying it but never measures up
There's nothing like the right tool for the job.And -usually- that's what I end up using.....nothing like the right tool for the job!
Looks great mike! Will it spit out hi-z as well, our did you route it solely for input purposes? Haven't checked out the structure of the non-trafo DI's, but it should at least be possible with the Jensen and the Pikatron.
Wow , i never knew that i neededa 51 x D.I. apparently i do [ now ]
Started by peter purpose « 1 2 ... 14 15 » The Lab
Started by jsteiger « 1 2 ... 7 8 » Preamplifiers
Started by Igor « 1 2 ... 6 7 » The Lab
Started by mikefatom The Lab
