mikefatom
kepeb said:so does that mean this is this input only?
Yes.
mikefatom said:One could use a simple Y cable though for a hard wire split, the same way it's done in stand alone DIs
But it doesn't look like it... Bummer. Still cool though!mikefatom said:kepeb said:so does that mean this is this input only?
Yes.
haima said:mikefatom said:One could use a simple Y cable though for a hard wire split, the same way it's done in stand alone DIs
in some situations you might need to use a isolation transformer inline with outgoing signal from the y-split cable - as there might be some ground loop current if this is going to a grounded amp for example... but i'm sure everyone knows that, no biggie.
looks like this'll be a cool unit mike!
grantlack said:Sorry for the lack of clarity, I was wondering if it was able to perform re-amp duties as well. Idk why I didnt just say that first!
Yes.
now we need more plugins to fill a second slot ;D ;D ;Dmikefatom said:... This is really going to change the way I record DI'd instruments! 8) 8) ;D 8)
3nity said:How many DI options are available??
I'll take 1 for sure.
If theres more DI options i take 2.
Thanks.
okgb said:I'll take one for support
the great thing about this is you don't have to patch different pre's
trying the the d.i. in's
Have you tried using more than one at a time
anything wacky or intersting ?
may be a good canidate for the drag control like radial
or something for impedance ?
