letterbeacon
Re: EMI RS124
« Reply #360 on: June 09, 2019, 09:24:20 AM »
I'm not sure about R13???  The lines are confusing though....
What do you mean? Looking again the voltage reading could be 195v rather than 145v, so perhaps it's not dropping 110V...
Rob Flinn
Re: EMI RS124
« Reply #361 on: June 09, 2019, 11:23:26 AM »
On the 436c diagram that point is 210v with no compression & 290v with 20dB compression.
On another emi mod 436b diagram it is 182v under no compression.
So 195v seems more likely.
regards Rob
rickc
Re: EMI RS124
« Reply #362 on: June 09, 2019, 04:19:55 PM »
re: losing 100v.
Yes, a resistor will drop the extra volts and convert it into heat.  Remember the heat, as it's a real factor and you need to get rid of it.
power is current squared times R.
The fly in the ointment here is that the current isn't quite constant, so the voltage drop will change as the current changes, and if you look at the
schematic, you can see that voltages change depending on the amount of gain reduction...
the original supply is a full-wave doubler,  which charges the last filter capacitor after the rectifier and before the dropping/decoupling resistors
to about twice the peak of the input voltage.  Further, they used a selenium rectifier which has a several volt internal drop.
Looking at the EMI schematic,  I see that the voltage that changes is the plates of the input tube, which makes sense since its grid
is driven negative by the gain reduction control voltage varying the plate current. More gain reduction means grids more negative means less plate current.
The input tube, V1 is the only current drain on  R13. With no gain reduction, that's  60v dropped thru 10k,  6mA. the threshold control is responsible for about 700uA of
that current.  With  however much gain reduction altec used for the measurement, the other voltage is 20v, dropped thru 10k, or 2mA.
Clearly, we are seeing that the doubler's current regulation isn't too stellar.  I think you can surmise that V1 is not quite cut-off under heavy GR conditions.
In theory, V2 is running  class A, so it's plate current shouldn't change on a drive dependent basis, and its grid voltage is not tied back into the GR control voltage,
so presumably its plate current is constant. The cathode voltage of V2 is a clue to how much plate current flows, 3.2v thru 220R is 14.5mA.
Adding the two currents says the drain on the supply is somewhere between 20.5mA and 16.5mA, a 4mA swing. Also note that the rectifier output voltage varies 10v depending on GR conditions. Let's ignore that for now.
So, your dropping resistor has to tolerate an approximate 4mA  current swing.
With your 250v transformer (it's 250v CT, right?; I'm too lazy to look back in the thread), the bridge rectifier delivers 352v (approx) to the filter capacitors. and we need 255v, which is 97v drop at 20.5mA, 4865R.
That's about 2W, so your dropping resistor should be a 5W part, and it will get warm. It should be wirewound. Maybe a mil-style part that bolts to the chassis is best. Let the chassis help get rid of the
heat. Of course, you'll need to adjust the value to the nearest standard value, which will depend on the resistor tolerance. It looks like you need to use 5k (that's what's available at Mouser),
and the 10W part is considerably less money.
https://www.mouser.com/ProductDetail/ARCOL-Ohmite/HS10-5K-F?qs=sGAEpiMZZMtbXrIkmrvidNw3CpujCJIJrQVroexDPy%252BzUvjXwMA15w%3D%3D
under GR conditions, the current changes to about 16.5mA, and this means about 80v drop thru the resistor, 352 - 80 == 271v. That's only 6v from what the EMI schematic says.  I'd try it that way.
The effect of the value difference (4865R to 5000R) is about 5v more drop. The other standard value is 4k7, and that's a 96v drop at 20.5mA. That's better, I'd go that direction. These parts are also available with axial leads
which might be easier to deal with, but do ensure that there's enough space around the resistor so it's heat output doesn't cook something else.
You could use a zener diode to further improve the regulation, but that's another topic for another day.
OH! I see you used a Hammond 269BX transformer, which you say is 300v ct, so the filter capacitor voltage will be 1.414 times 300, 424v. You can grind the math, and see the effect. the dropping resistor will get hotter. You may need that zener.
letterbeacon
Re: EMI RS124
« Reply #363 on: June 09, 2019, 05:14:49 PM »
Firstly, thank you very much for your very informative post - it's made things much clearer to me and I really appreciate that!
Secondly, I do in fact have a 369AX not the BX. That was just a typo from me earlier in the thread.
So what you're saying is that rather than replace R13 and R14, I should insert a dropping resistor right after the rectifier to bring the voltage down to approximately 255V, which then supplies R13 and R14?
This makes total send - thanks a lot!
rickc
Re: EMI RS124
« Reply #364 on: June 09, 2019, 06:42:01 PM »
ok, I took the time to see what the 369AX is about. so it's 250v ct as I originally thought, and it's 115mA current output. Note that transformers are measured at rated current, so the 369AX will deliver more secondary voltage when operated under its rated current.  the extra current can be used to your advantage via a bleeder resistor.
The point of trying to get close to what Altec did is to try to establish the same operating conditions, and since the stages operate from the same common point, it makes sense to try to get the standing voltage at that point the same as it is in the Altec.
You might also investigate using a bleeder resistor across the output of the dropping resistor. The effect here is the bleeder current swamps the variation in current caused by the input tube, which then minimizes the effect on the voltage drop in the series dropping resistor.  In the old days, when a voltage regulator represented a lot of extra circuitry, a bleeder resistor was a common solution to the problem of minimizing the effects of dynamic current swings on an unregulated supply.
letterbeacon
Re: EMI RS124
« Reply #365 on: June 12, 2019, 06:10:45 PM »
I've just installed a 5.6k 25W resistor directly after the bridge rectifier and I have some slightly strange (to me) results.
The voltage is now much lower than I anticipated.
The voltage after the bridge but before the new resistor is 284V whereas before I installed the resistor I measured 363V after the bridge.
After the new 5.6k resistor the voltage reads 198V. This then means that all the other voltages after the 5.6k are all around 20% lower than they should.
Based on the maths that rickc very kindly worked out, I thought that a 5.6k resistor will drop approximately 100v, bringing the rest of the voltages in line through the rest of the compressor, but it appears now that the voltage before the new 5.6k has lowered to lower than I need it to be. I don't understand this...
rickc
Re: EMI RS124
« Reply #366 on: June 12, 2019, 06:36:16 PM »
how large are/is the first filter capacitor? did you stick with the bridge rectifier?
since you're in 50hz land, the filter capacitors should be somewhat larger, 15-25% because of the lower ripple frequency.
I'm guessing that maybe the filters are a bit undersized, and we're seeing the change in voltage due to load.
rather than agonizing over it, you can just adjust the value of the dropping resistor to get the right voltage.
letterbeacon
Re: EMI RS124
« Reply #367 on: June 13, 2019, 05:31:00 AM »
The filter caps are 50uf, so perhaps that might be the issue. I'll change C7 to 80uf like the schematic, but C8a will have to stay at 50uf as it's shares a can with C8c.
In the meantime I think I have a few 3W axial resistors I can put in parallel with the chassis mounted 5,6k to bring the resistance, and hopefully the voltage drop down.
Thanks for your help with this.
letterbeacon
Re: EMI RS124
« Reply #368 on: June 15, 2019, 10:57:48 AM »
I've put a 6.8k in parallel with the 5.6k dropping resistor and now by voltage afterwards is 240VDC, which is close enough to the 255VDC it says on the schematic. As it's an old design, I reckon within 10% should be fine.
The meter is is still pegged to the right and I'm don't think it's compressing.
My meter is 100uA, the schematic calls for a 200uA. I worked out that I need a 1K shunt across it, but I've used a preset pot and dialled in 1k, with the thinking that I can fine tune the needle to zero if needed.
I don't think it's the shunt though.
The compressor doesn't seem to be compressing as when I turn up the input pot instead of getting more compression, the signal starts to distort.
On the schematic, when I have 20db compression, I should get a rise of 10V after the diode bridge, and the voltage at the plates of V1 should rise by 100V.
I can't measure the amount of compression because my meter isn't working, but when I increase the input pot so I get a rise of 10V at the diode bridge (although actually after my new dropping resistor) the plate voltages on V1 only rise by 10V, not 100V.
I've double checked my wiring of the sidechain but to no avail.
Does anyone have any thoughts at all?
Rob Flinn
Re: EMI RS124
« Reply #369 on: June 15, 2019, 12:54:24 PM »
You have a problem either with the sidechain, or the sidechain signal isn't getting to the 6bc8.  This is a very simple compressor so it should be quite easy for you to check for mistakes.
regards Rob
rickc
Re: EMI RS124
« Reply #370 on: June 15, 2019, 01:27:28 PM »
what rob said.  you have a sidechain problem. Ignore the meter for now.
using a DMM or other high-impedance meter, measure the voltage at the PLATES of the 6AL5, which should be connected together.  that voltage should go negative, and proportional to signal level, AFTER some amount of initial drive. That offset is the threshold level. In the 436C, there's a pot for adjusting that. In earlier units, the threshold is fixed, I believe at the cathode voltage of the 6CG7,.
anyway, if you can get that part working, then measure next at the grids of the 6CB6, which should track the voltage from the 6AL5.
more negative means more gain reduction.
thomasdf
Re: EMI RS124
« Reply #371 on: September 18, 2019, 02:21:08 PM »
Hello everyone
I am building a stereo tube compressor which is very closely inspired by the EMI RS124.
I am supposed to use a 1:1 input transformer with a center tap.
I have a pair of Altec 15335A transformer ( 15K:15K) sitting here unused... Can I use them for such a duty, knowing that they don't have a center tap? Must I "simulate" a center tap of some sort with carefully chosen resistors (any help welcome!) or can I omit the center tap ?
Here is a bit of the schematics
Re: EMI RS124
« Reply #372 on: September 20, 2019, 09:13:25 AM »
You need the centre tap as a means to inject the voltage from the side chain but you can just use a pair of resistors as you said.
The values you already have on your schematic look like a good place to start.
Is the input attenuator before the transformer in your particular schematic?
thomasdf
Re: EMI RS124
« Reply #373 on: September 22, 2019, 01:55:25 PM »
Ok, then can I omit the link between the two 39K resistors and the center tap of the input transformer, the two resistors acting as a false center tap?
Yes, absolutely... I was surprised at first but it is a praised compressor, so I guess it works just as well ?
Re: EMI RS124
« Reply #374 on: September 22, 2019, 10:23:01 PM »
Yes, use the connection of the two 39k as your centre tap to inject the control voltqge.
It's not unusual to have the input gain before the transformer, it's done that way on lots of other units.  There are some benefits such as no mismatched tracking of a dual pot to deal with, and a smaller transformer can be used since it will see lower signal levels.
The downside is that the input is lowish impedance and most probably unbalanced (haven't seen your particular scheme so?) but that's not a big deal in actual use.
Post the schematic if you can 👍
Edit p.s. : Check for any overshoot of the transformer with those 39k values if you can.   It's possible that your 15335a transformers are happier with lower values but I wouldn't know off hand.
« Last Edit: September 22, 2019, 10:39:10 PM by Winston O'Boogie »
thomasdf
Re: EMI RS124
« Reply #375 on: September 25, 2019, 01:30:30 PM »
Hello
Thanks for the detailled answer.
I am legally not autorised to post the schematics for everyone to see, but I can sure send you a DM with some files.
As for the virtual center tap, my transformer has a .5 ohms resistance over the secondary, so I guess 2x39K is way over the top?
Re: EMI RS124
« Reply #376 on: September 25, 2019, 08:36:00 PM »
No, I don't think your 2 X 39k is necessarily  way over the top.  Just use those values and, once you have it built, measure the frequency response.  Worst case is that there is peaking at the high end in which case, come down in value.
Last post October 11, 2010, 12:12:36 PM
by EmRR
Last post October 08, 2010, 09:55:23 PM
by gary o
Last post May 12, 2012, 05:40:42 AM
by letterbeacon
Last post June 08, 2019, 09:23:15 PM
by rickc
