creal
Hi everybody
I need info for racking the 8108 channelstrips.
These modules have an out put level of -10 and would need to be boosted to + 4 with the Ba 283 card and assosiated transformers.
I found this info here:
http://www.auroraaudio.net/dcforum/DCForumID1/901.html
Do you think it's the better way ???
if it is, it's seem the BA283 and LO1166 is the best combination. So the LO1166 is hard to find and looks expansive.
After reading so many post about this pair, i find the link below, look at the last post:
http://www.gearslutz.com/board/geekslutz-forum/104550-search-lo1166-transf.html
direct replacements for the LO1166 as used also by Neve.
Audio Maintenance Limited Transformers and Inductors
CA-18-VTB1148 - Transformer: Audio Output (Narrow Board Version)
CA-18-VTB9049 - Transformer: Audio Output (Standard Version)
What did you think about the CA-18-VTB9049 to replace the LO1166?.
More expensive alternative (but i not sure it's better)
JLM111DC Output transformer JLM111DC Output transformer
Master's i need you knowledge.
thx for your help
thx for your help
