zayance
Re: MixBuzz1 Build/Support thread
« Reply #20 on: December 22, 2010, 04:17:01 PM »
  ??? I'm looking at the board and following traces it seems to be correct on PSU board and Main board, only the 7815 is not written on PSU pcb for VR5 positive Reg.
« Last Edit: December 22, 2010, 04:23:55 PM by zayance »
jandoste
« Reply #21 on: December 23, 2010, 03:35:12 AM »
Thanks Zayance,
Any body has any reference for EAO pushbuttons( Farnell) ?
Edit : maybe Igor can help us :)
« Last Edit: December 23, 2010, 08:15:48 AM by jandoste »
baadc0de
« Reply #22 on: December 23, 2010, 03:42:14 AM »
+1 me too
zayance
« Reply #23 on: December 23, 2010, 05:27:04 AM »
There are other options for illuminated pushbutton than EAO, Farnell has a brand called Rafi, i'v just bought two of them, all these are expensive, but you need to buy the cap, the lamp or LED your choice, and also the legend insert if you want to add something inside but it also serve as the look of the switch without it you see the lamp.
Has to be latching.
http://fr.farnell.com/jsp/search/browse.jsp?N=500001+1002062&Ntk=gensearch_004&Ntt=rafi&Ntx=mode+matchallpartial
And Mouser has NKK switches and this series model, do your search using the factory refs in mouser looking at the spec., but this one is momentary the difference in the spec is:
Momentary ON-(ON) and latching is written ON-ON and you want it latching. These are small tough 8mm body.
http://www.nkkswitches.com/pdf/hbilluminated.pdf
http://fr.mouser.com/ProductDetail/NKK-Switches/HB15SKW01-6B-JB/?qs=ZOQelsdDI4LKVWSnFNq26A%3d%3d
If this can help? There are i'm sure other hidden options in other suppliers also, like conrad.fr or.de etc...
« Last Edit: December 23, 2010, 05:37:13 AM by zayance »
baadc0de
« Reply #24 on: December 23, 2010, 06:02:54 AM »
So, something like this?
http://fr.farnell.com/rafi/1-15-108-151-0000/switch-pushbutton-latching-illum/dp/9927646
I (think) we're asking about EAO because some of us got engraved lenses for them from Igor and ofcourse we'd like to have a compatible switch to insert it into.
zayance
« Reply #25 on: December 23, 2010, 06:21:30 AM »
Yes something like this, but it's another story if you got some engraved lenses, i can't tell if they will fit, but the info could interest any other builder looking for that kind of switch.
tomcat
« Reply #26 on: December 23, 2010, 01:37:01 PM »
The lenses will not fit most of the other switches.
The EAO you can find at Collins http://www.audiomaintenance.com/
baadc0de
« Reply #27 on: December 23, 2010, 03:14:20 PM »
jandoste
« Reply #28 on: December 23, 2010, 05:39:13 PM »
Oh, so http://www.audiomaintenance.com/acatalog/EA-03-001_extended_info.html this one then?
I think, Igor will give us all infos that we need ! tomorrow :)
Great news about MixBuzz1!
We shipped Dec 12th-21st orders at Dec 21st.
I had very busy week, sorry. Saw some support threads needs an answers,
will have a time for this tomorrow.
jandoste
« Reply #29 on: December 24, 2010, 10:41:55 AM »
I got some questions :)
any idea? Thanks
« Reply #30 on: December 24, 2010, 02:05:17 PM »
Hi guys, sorry, had no time, a way busy week.
Finally, got flu'ed and +38degC, at home and drinking hot tea wit honey and lemon)
After checking the questions, all they are matter of read before ask, or RTFM.
Anyway,
Please attention!
For reference, here is the file with kit's description (named Kits)
http://twin-x.com/groupdiy/displayimage.php?album=416&pos=1
This way, you can easy locate every component.
Something to do to use 4x2180? Pin 4 lifting trick?
I found more than enough info here:
http://www.thatcorp.com/datashts/dn137.pdf
http://i1236.photobucket.com/albums/ff442/jandoste/Ratio.jpg
This is attack/release board. Please check at the start of this thread:
Any clues on how to implement/calculate CR1, CR2, RR1 and RR2 for the Release ?
By ear, take potentiometer and capacitor or 2 pots and 2 caps.
Logically, for 0.9 sec setting release, (between 0.6 and 1.2) use 750 or 820k and 0,47uf.
Rolls music increased a bit maximum release (last setting) and did
"dual release" push-button instead of A setting.
Don't affraid to experiment
Components supplied with kit:
BASIC_KIT.TXT
C-POLY, 5MM PITCH, 50-63V:
1   0.47U   C5/4.5        C37
1   0.47U   C5/4.5        CR4
RELEASE, 5TH POSITION OPT IS 0.9 SEC:
1   0.47U   C5/4.5        CR1
1   750K      RR2   *INSTALL JUMPER AT RR1
- on C&B RV_1| RV_2 | will have 100r ? if I use all options (SC-MIX etc etc)
RV_1| RV_2 : 33R...120R, 1/4W, metal film, no need to install them if meter board not used
- Do I must put Ratio's 500r Trim pot ? if I use all options?
[/quote]
Yes)
http://i1236.photobucket.com/albums/ff442/jandoste/R.jpg
- R6L and R6R TBD ?
Really frequently asked question :)
Reference1:
http://www.groupdiy.com/index.php?topic=39459.msg487554#msg487554
If you use DBX202X or other type of VCA which should have input resistance in-series,
in case of replacement board (supplied with PCB set), use 0R (JUMPER) at place of R6L and R6R
For reference2,
AUDIO_BOM.TXT:
2   TBD                1/4W METAL FILM 1%        R6L, R6R !  INSTALL 0R WITH REPLACEMENT BOARD
! DEPENDING ON VCA USED, VALUES SHOWN FOR REPLACEMENT BOARD WITH 4X2181
RESISTORS INCLUDED FOR 3 BUILDS:
DBX202X
R6=3K74, R3=4K99, R100=909R
REPLACEMENT BOARD 1XVCA
R6=JUMPER (0R), R3=20K0, R100=909R.
REPLACEMENT BOARD 4XVCA
R6=JUMPER (0R), R3=4K99, R100=909R
Igor, I didn't receive 360k, 750r0, 470k, 200r, and just I got one 2k4! I got a lot resistor M
Please check twice, because we checked twice as well before sending the kits.
However, all we are people and there can be human factor mistakes. Please check and let us know.
If something is missing, we'll send it.
On the main board PS is,
1 /-15V
2 /+15V
3 /-18V
4 /+18V
5 /AGND
6 /AGND
7 /-12V
8 /+12V
9 / Case
But on PSU board not the same ?
Main and PSU have absolutely same pads for same voltages on 9-pin, 5mm step interconnector.
1=1=-15, 2=2=+15, etc.
2-pin terminal used for connection of external meter LED board, 12V POWER lamp, etc.
-12V is "digital" (relays and LED display) ground.
Hopefully, yes.
To clarify about EAO pushbuttons and lenses.
I used EAO 01-281 latching pushbuttons, bought about 2 years ago on evilbay.
Some people had same pushbuttons and asked about engraved lenses, and these lenses with engravings were sent for free with PCB's.
There are some latching pushbuttons which use same 16mm cutout, this one can be used, for example:
Just print the "legend" on presentation HP "photofilm" or something like this, it will look neat as well.
http://i1236.photobucket.com/albums/ff442/jandoste/20k.jpg
There are 2 variants of VCA replacement board assembly. As I can see on picture, 4 vca's used.
This way,
http://twin-x.com/groupdiy/thumbnails.php?album=416
FILE: DOCS_v2.4.ZIP
Go to VCA sub-dir
If 1xDBX2181 used, same sub-dir, file: 1x2181vca.png
732R resistors supplied with kit, in case of whatever:
BAG12 DBX202X REPLACEMENT BOARD
ALL COMPONENTS FOR 2XVCA REPLACEMENT BOARDS  (SINGLE 2181 VCA)
SPARE RESISTORS FOR 4XVCA UPGRADE INCLUDED
2 22...47 PF CERAMIC CAP PITCH 5MM DON'T USE WITH OPA604 AT PLACE OF IC9
CAPACITOR-POLY', 5MM PITCH, 50-63V
2   0.1UF  C5/2.5          C44
RESISTORS
8   5K1   1/4W METAL FILM 1%     R9, R10, R11, R12
8   20K   1/4W METAL FILM 1%     RI1, RI2, RI3, RI5
2   100R0 1/4W METAL FILM 1%     R102
2   732R0 1/4W METAL FILM 1%     R101
IC
2   THAT2181B           U$2, U$3, U$4, U$5  #1354172 ETC
2   NE5534   IC9
« Last Edit: December 24, 2010, 02:42:34 PM by Igor »
http://www.ij-audio.com
(new site hopefully will be up in July)
jandoste
« Reply #31 on: December 25, 2010, 08:19:58 AM »
Did anyone already got this switch? [for the Mix] I didn't receiev it and I finished my farnell list just I need to know what is it exactly? I searched in docs_v2_4 2 but didn't find it!
Igor, there is lots of parts(resistors,capasitors,two switches for soft|dual) are missing but I will buy them from farnell!
Thanks for the infos !
jandoste
« Reply #32 on: December 29, 2010, 07:07:09 AM »
Bump :)
« Last Edit: December 30, 2010, 03:33:24 AM by jandoste »
zayance
« Reply #33 on: December 29, 2010, 12:27:38 PM »
Hey Jandoste, well it s not a switch but a pot, Alphastat pot to be exact, now maybe one of his left stock from the Sontec builds, so it could be a 4196 100K Rev Log pot, or a 4195 50K Rev Log, if this can help, but i think the Mix pot is discussed somewhere in here, Crushn'Blend thread or something, maybe you can find your answer, at the end it's a pot that allows you to sweep between wet and dry signal....
baadc0de
« Reply #34 on: December 29, 2010, 03:51:38 PM »
Some CnB builds have it as a 10k lin? Maybe that applies
jandoste
« Reply #35 on: December 30, 2010, 03:49:19 AM »
Thanks Zayance,
I  find it here http://www.alphastat.de/products/alpha/alpha.html
but I just need one pot and I don't want to pay 15$ to UPS :) I'm trying to find Farnell# code if I should :)
« Last Edit: December 30, 2010, 03:55:39 AM by jandoste »
zayance
« Reply #36 on: December 30, 2010, 04:09:44 AM »
Yes of course i wasn't saying go for alphastat, just making it clear that it's not a switch now wich pot to use i dont know, but with a little search you'll find your answer i'm sure.
KrIVIUM2323
« Reply #37 on: December 30, 2010, 09:29:33 AM »
Hi all,
i didn't have the pot either in the parts received with kit.
The value of pot should be dual 10k linear according to SslTech schematic found here:
http://www.groupdiy.com/index.php?topic=8360.0
jandoste
« Reply #38 on: January 02, 2011, 04:22:33 AM »
Hey Guys,
Happy new year !  Happy new year !  Happy new year !
I almost finished to my unit but just I want to be sure all wires connections are right ?
if you have any idea it will be great !
« Last Edit: January 02, 2011, 04:30:03 AM by jandoste »
jandoste
« Reply #39 on: January 03, 2011, 11:59:05 AM »
Igor,
Can you  please add the LED meter calibration?
P.S.  Maybe I am alone for building this project :)
Last post January 08, 2020, 01:13:55 PM
by Spencerleehorton
Last post June 23, 2020, 02:23:05 PM
by jsteiger
Last post June 19, 2020, 08:55:58 PM
by zonkola
Last post July 09, 2020, 03:10:25 PM
by kato
