hop.sing said:Neumann uses ceramics and Andreas Grosser in his mods, too.
rodabod said:4.7pF any good for you?
Gus said:Carefully lift one side of the cap to find out if it is the cap. The gain will go up but it will help you find the problem. I have twisted wirewrap wire measuring with a good meter to make "gimmick caps". My guess is the caps were custom made, you can find down to 20Pf sometimes.
Really? The one I have in front of me is definitely a polystyrene. Maybe they changed over at some point?
Well, i used a ceramc cap in my km84 build and the microphone is very quite, so no problems there. But the two leadouts of the cap are pretty close to each other so I cleaned the room in between carefully with alcohol, it did not hurt the ceramic cap, but I do not know if polyprop will survive that, so distilled water is a good idea there.Gus said:Something to try is to clean the cap body with distilled water using a clean wipe like a Kimwipe. Then dry it off.
