I don't know if it would be better, but certainly different. The big advantage of a choke load is the accumulated magnetic energy that allows twice the voltage swing for a given B+, but a SS ccs would be almost totally exempt of the non-linearities of a real-world inductor.lassoharp said:Yeah, that type of thinking is like you said - aimed at forcing the tube away from it's characteristic curve. It always sounds good on paper. I'm interested in seeing if it improves the load efficiency - ie would it be better than a choke load.
Kingston said:I wonder what an active plate load does to sound. "pure" current source, right? On paper it removes all "tubeyness" from the plate curves: your load line is now a straight horizontal line, like with a plate choke. Common sense would dictate it results to very very sharp clipping (one end) or blocking distortion (other end) when one runs out of headroom. Any point in using tubes there anymore, forced absolutely linear?
Tests regarding this are on my todo bench list.
analag said:Have YOU ever tried it. Try it then talk about it. Then and only then will you be emitting facts.
gyraf said:Every time I have tried hybridi'fying by mixing in such solid-state linearizing add-ons, I've ended up with a circuit that measured and behaved better "on paper", yet did not at all match the subjective perceived performance of a simpler uncorrected setup.
This may very well be due to some deficiency in my perception, but the difference is so clear (to me) that I have given up on such designs a long time ago.
Jakob E.
The values of R2 and R7 not been divulged, it's a tad difficult to estimate. Now, if I understand well, these are pots, so R2 would be reduced only for very high level signals. The input impedance varies with the inverse of the 1st stage gain, so the microphone would see a really improper load only at very low gain settings, so it is an acceptable compromise. Still I don't really like the idea of varying the input impedance as a function of gain.mjk said:"One major problem I see in this circuit is current feedback, which yields very low input impedance. IMO, all other benefits the fancy design claims are ruined by this."
This does result in low impedance, but how does low impedance ruin the benefit? The first stage impedance results in the expected loading for most microphones,
Low Z is not a guarantee of low noise; very often ground arrangement becomes more critical.The low impedance and local feedback results in good noise rejection.
Why give us a half arse schemo to analyze ???.mjk said:I'm sorry, I should have mentioned that it's a simplified schematic.
analag said:Why give us a half arse schemo to analyze ???.mjk said:I'm sorry, I should have mentioned that it's a simplified schematic.
emrr said:analag said:Why give us a half arse schemo to analyze ???.
That's a very silly question, which shouldn't need explaining. Post the PM660 publicly yet?
