A compatible case?
Lalalala
Member
I am setting up a PC-based recording system. I have
purchased all my parts for the computer--however, I cannot find the Ahanix Noblesse case that was initially recommended for it!
Can you recommend a case that would be good and compatible for the set up listed below? Thanks!
1 Asus P4P800 DELUXE Intel P4 865PE 800FSB - DDR Dual-Channel PC3200 ATX Motherboard With AGP PRO 8X, 3Com Gigabit Lan, ASUS AI Intelligence, SATA, 1394, USB 2.0 and RAID
ENERMAX EG465P-VE(FCA)-430 Watt
Intel P4 3.0G 800FSB (Northwood C not 533FSB Northwood B)
512Mb PC3200 DDR400
Plextor PREMIUM 52 X 32 X 52 Internal ATAPI Retail Box Black Color CD ReWriter
1 Mitsumi 1.44 Black Floppy Drive
1 Western Digital 80 GB 7200 RPM ATA 100 WD800JB 8MB Buffer
1 Matrox Millennium G-450 32 MB DDR Dual Head AGP OEM
1 WD Raptor 36GB Serial ATA SATA150 10,000 RPM Hard Drive - WD360GD
Dr. Alan Lipman
I'd go with the Lian-Li stuff. They're kinda expensive but they have great features, are easy to load and are aluminum. I think the 61 is the one that I've used...
Good luck and feel free to email with any problems. I build lots o' PCs.
Have you considered a rackmount case? I got a decent aluminum rackmount case off ebay a while back for like $80 w/ power supply. Pulled the powersupply, drilled and threaded some holes, and Voila! I racked my g4 Mac. Weighs like 6 lbs. less than it did in the standard mac case. Anyway, just a thought. Nathan
