GreenFog_Studios
Active member
I bought an unknown tube pre amp and the seller said that most likely radio/turntable console. It has mono rca connector in and out which are just marked analog. I plugged an SM58 into it with an XLT to RCA cable and ran the out to my studio mixer to see how it sounded. To my surprise it sounded great. Clean, warm and plenty of gain. I'm going to mount panel mount XLR and 1/4" ins and outs. My question is if it is RIAA phono how does that impedance compare to a standard 600 ohm mic pre? Should I mount a mic to line or mic to something transformer to get the most out this thing? I'm not worried about the output as I can use simple direct box components to get the correct levels for going into compressors and recording inputs.
