Rocinante
Re: Collective Cases - PSU cases, ez1073, CLX cases and PCB's.
« Reply #400 on: August 21, 2016, 05:17:07 AM »
Oops I almost forgot.  Dan your case is awesome.  I took my time drilling the 40 holes I needed to make. Everything fits nicely and the case itself is ridiculously simple to assemble. Populating the dc filtering pcb now. Thanks a bagillion
Dylan
If there's a harder way to do this, I haven't found it yet.
erquere
« Reply #401 on: August 21, 2016, 05:40:58 AM »
I already got the PCBs from you :o)
Another question, please : which Hairball ratio switches and meters do fit to your case ? As I'll buy yours (but later)...
Best regards- and I won't disturb u more
Used to be a journalist but I prefer build comps and eqs
Blackdawg
« Reply #402 on: February 27, 2017, 08:28:44 PM »
So i just had a custom panel cut from Front Panel Designers for my NeoTek Channel strip project....and the damn stock mounting holes don't line up  >:(
What kind of holes do the normal 2U cases take? in FPD i can pick 4 options for the "System Holes"
Part front panel (fishcer)
Front Panel (Fishcer)
Part front panel (Schroff)
Front Panel (Schroff)
I don't see any change when i pick either option.
Or do i have to put in custom holes to bolt my face plate to the case?
Any advice would be helpful...100 test face plate now worthless.
dandeurloo
« Reply #403 on: February 27, 2017, 11:12:02 PM »
Blackdawg, datasheets for the front panel hole locations are on my site.  Here is a link.  I hope these help.
http://collectivecases.com/?product=blank-front-panels
Dan
PROFESSIONAL CHASSIS AND FRONT PANELS FOR DIY PROJECTS: WWW.COLLECTIVECASES.COM
Dan Deurloo
www.collectivecases.com
www.risendrums.com
Blackdawg
« Reply #404 on: March 20, 2017, 04:46:14 PM »
Dan
D'OH!
Thank you Dan!! Life saver.
MasonAtom
« Reply #405 on: July 10, 2017, 03:37:41 PM »
Quick question about the SZL-54 transformer - will this fit in a 1U rack? What is its height?
« Reply #406 on: March 14, 2018, 07:20:34 PM »
Hey everyone, Hey Dan!
I'll be needing a case for a PYE soon, I'm putting together a mouser list, could you let me know what switches for the stereo link and the power?
If you don't know the exact models, at least the thread diameter and angle of switching?
Joao
jrowel: "It depends on how much is wrong with the module. There is something wrong with almost all of them. "
ruairioflaherty: "Mr. EMI's children have bigger problems than some solder monkeys"
dandeurloo
« Reply #407 on: March 18, 2018, 09:07:46 AM »
I was given all the info from Abe for the requirements of the case and front panel.  So, I don't have the exact part number on hand.  I wonder if someone else who has built them would have it.
If not, I am slowly building up mine own Pye comps currently.  I am to the point of sitting down and wiring this baby up.  So maybe check back with me in t bit and hopefully I will have the info.  I am 99% sure Abe spec'd a Lorlin for all the pots and they are included in the BOM that is floating around.
https://groupdiy.com/index.php?topic=43351.0
(I think the BOM is complete in the thread as well)
Talk to you soon.
Dan Deurloo
www.risendrums.com
originalscottyg
« Reply #408 on: April 10, 2018, 08:55:59 PM »
Hi Dan.
I wanted to let you know that somehow I got onto an old website of yours at cc.fourfourmedia.com, which looks exactly like your current site.  I tried to check-out several times,  but kept getting a paypal error about the merchant's email address.  I then followed the support link and sent you an email that I'm guessing disappeared into the ether.  I did finally find my way to the correct site and just placed an order for a couple of ez1073 cases (thanks!).   I just wanted to let you know, in case you weren't aware that the old site was still up.  Cheers.
Scott GatteƱo
"Violence is the last refuge of the incompetent." Salvor Hardin
« Reply #409 on: June 23, 2018, 09:47:58 PM »
Hey Dan
Thanks for getting in touch with me! Love your work.
Brian
« Last Edit: June 23, 2018, 10:05:48 PM by theonlybrianarnold »
OneRoomStudios
« Reply #410 on: March 28, 2019, 09:02:51 AM »
Hey Dan,
Two questions
-For the tube mic psu (xlr), what is the part number or series for the indicator lamp?
-Would it be possible to get a tube mic psu case with four xlr holes instead of two (I'm making a stereo pair of tube mics).
Bobby Baird
« Reply #411 on: September 18, 2019, 03:19:02 PM »
2u Basic case received today. Would you happen to know the diameter size of the hex screw for the face plate? Is it metric or standard? Thanks again.
dandeurloo
« Reply #412 on: September 18, 2019, 03:36:30 PM »
Hey Bobby, the are 8-32.
Talk to you soon.
Dan Deurloo
www.risendrums.com
funkymonksf
« Reply #413 on: January 21, 2020, 09:41:32 PM »
Nm
« Last Edit: January 21, 2020, 09:46:38 PM by funkymonksf »
dandeurloo
« Reply #414 on: January 22, 2020, 03:21:41 PM »
K, :) :)
Dan Deurloo
www.risendrums.com
rackmonkey
« Reply #415 on: January 25, 2020, 12:41:10 AM »
Hey Dan. Do you have any other specs for the input transformers you have on the site? Wondering what the max level on both of those inputs is (P-A111 and P-JO23).  And dimensions would be helpful as well.
Thanks much. Nice work!
Whether you think you can or you think you can't, you're probably right.
