delete
measure across the full +/- (should be around 48vdc)
is it really dropping?
disconnect the 0v interconnect and measure between supplies/rails.
is there a big difference between the grounds?
is there continuity between the ground prong on the plug and chassis and 0v on both?
if so thats a common ground, maybe not the best though.
what if you put a diode (1n400_?) in series with the output of rails--forward biased(?).
not a solution but maybe a remedy/bandaid?
seems something is not right with regulators.
try sense connected at the source to rule that out.
with the diodes, pull all but 1 module to give the diode a chance if you don't have big ones--just troubleshooting here.
