Is someone going to make panels? or do we diy... FPE / Schaeffer?
RE:500 series, how are you getting 24v? DC-DC converter? or have you reworked the circuit to run off +/- 16v?
Dan (collective cases) has said he would be happy to make the 1U cases.... not sure about the 500 series version.... I'll draw the front panels out in FPE so you can make your own anyway should you so desire.
It simply creates the 24v using a linear regulator.
Forgot to ask, will we be able to use ed andersons input transfos with these for us US folks?
No idea..... if it is mechanically the same then yes.... if not then no.
Will you be offering full kits? or just PCBs and partial kits?
I intend to simply pass on the finished files to Gustav.... who (I presume) will be willing to make the PCB's.... won't be doing full kits.... but I will probably do a colourbook for each so that it is easy to make them.
I will need to create a revision 2 of each which will take 3-4 weeks to do....and then I'll get Gustav on the case.
There is also a new mains transformer being designed for the 1U version.... but that is still in development.
Colin
www.audiomaintenance.com
