guitar4444
- Joined
- Oct 1, 2009
- Messages
- 103
Hi Tommy,
I tried that, in the end moved the transformer to the back of the case and rotated to the best spot, I compared that to having the transformer out side the case. Once the transformer was moved to the back of the case most of the residual hum is from an earth loop in the supply so moving the transformer further back than the back of the case wasn't worth it. The hum is at about -90db and only present when the EQ is engaged. Apparently that level of hum in the EQ circuit is about 10db better than the original Neve layout. It maybe possible to get a better result by having a completely external supply or even a 24 volt battery supply would give zero hum. Aside from that I was about to experiment with splitting the round plane on one unit but decided to leave it for the moment as in practice the noise is negligible for most applications that you would use a Neve pre for.
I will build an external supply in the not to distant future.
cheers Greg
cheers Greg
