Hello,
For a few years already I have this rack with 4 D&R " compr/lim. II" and 3 "noise gate II" in it.
Crackly pots, one broken off, a big wiring mess inside,... I actually only ever used channel one as it turns out to be a great drum room smasher. I've promised myself to get them back to a good working state one day and I consider 2011 to be a good day
comp circuit: http://www.d-r.nl/Service Parts/Compressor-Mono.PDF
gate circuit: http://www.d-r.nl/Downloads/NoiseGate-Manual.pdf
pics: http://www.gyraf.be/diy/dnrcompgate/
There's a discrepancy between comps 1-2 and 3-4 as seen in my pictures.
3-4 have a few components removed (the blue thingies) and newer caps (470/40v)
There's also a mix of older and newer resistors
Short of replacing all caps and pots on these boards, are there any other things I could or should change? (opamps?)
Also, these are unbalanced units and it is in no way clear to me at what level they operate - any need for change in that department or shouldn't I bother?
Thanks in advance
Herwig
(diy newb - can't read circuits, knows a bit about components, can solder, persistent - I searched the forum/net for answers, if I'm asking questions that have already been answered, please let me know and point me in the right direction - thank you)
Thanks in advance
Herwig
