wowi
Re: SSL 9K & 4K (E Series) 500 / 51X NEW BOARDS Mic Pre Thread 2011
« Reply #620 on: June 28, 2020, 10:16:13 AM »
Hi, i  just powered up and R2 exploded. Without meterboard everything is ok.
I think, there was extra copper on the meterboard with a short power to ground. But the image has lost.
Can someone tell me, where exactly i had to cut a trace on the meter board ?
Wolfgang
« Last Edit: June 28, 2020, 11:01:35 AM by wowi »
TillM
« Reply #621 on: June 28, 2020, 12:07:13 PM »
Yes there is a problem with grounding at the meter board.
When the led are in front of you, it’s the opposite the left side.
*when die LEDs von dir wegzeigen, dann ist es die linke untere Ecke.
Dort musst du ein wenig vom Kupfer abtragen.
Ricardus
« Reply #622 on: June 28, 2020, 04:26:05 PM »
That issue is from older revs, right? I wonder how old his board is.
Audio mastering for hire..
wowi
« Reply #623 on: June 29, 2020, 07:38:18 AM »
I just checked the led PCB and it's a correct version . No short.
The problem remains the same. R2 is Smoking. I have to check again this evening.
TillM
« Reply #624 on: June 29, 2020, 10:47:14 AM »
I don’t think that there was ever a revision.
Just remove some copper at the left side at the LED meter board.
R2 is always smoking, when you have a grounding short.
wowi
« Reply #625 on: June 29, 2020, 11:45:16 AM »
Hmmm... I just noticed: IC4 (tl074) was smoked also. Its the driver stage for the led
Last post April 24, 2019, 06:18:12 PM
by Mrosso
Last post August 03, 2010, 09:15:25 AM
by jsteiger
Last post July 23, 2019, 01:04:02 AM
by boji
Last post May 22, 2011, 09:16:50 AM
by [silent:arts]
